Question about One For All URC 7740 Remote Control
I have remote control urc7740 need code for it
  • 1 more comment
  • bouze Jan 28, 2009
    I have a URC 7740 remote control but when I try it, it won't work I Think I need a code
  • cornishnutte Feb 10, 2009
    got the same i did to get the code for my dvd player or if i can do a scan for it
  • rutie Feb 13, 2009
    lost the instructions and need a code
  • 928 Answers
You can go to the link below then enter in your model. your device and brand then click submit to get the code.
Posted on Jan 01, 2009
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
I have a URC7740 RO1 and am looking for the code for an Audioline FTA3000 set top box can you help please? -
manual above.and more info below.
OK, this is about all the info i could find.
Aug 04, 2010 | One For All URC 7740 Remote Control
I have a urc 7740 tv control and it is not working? I have been told I need a code how to gain this?
Copy and paste this into your browser. Then click on Download. Cheers.
Feb 08, 2010 | One For All URC 7740 Remote Control
Bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Aug 26, 2007 | Televison & Video
One For All URC 7740 Remote Control Logo
77 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
