Question about Microsoft Windows XP Professional for PC
I formatted my pc 2 days back...so needed drivers...i already had saved sound driver compatible withmy pc...but when i run it it says....."THIS PROGRAM IS USED INTERNALLY BY PACKAGEFROMTHEWEB.IT SHOULD NOT BE EXECUTED DIRECTLY" Neither i am able to install via device manager.furthur i am not getting the driver on net.Please fix my problem... Model:HP 7540 Desktop Sound Driver:sp36228,hp
  • 2 more comments
  • Anonymous Jan 12, 2009
    It is displaying an error message,Limbu pls hlp
  • Anonymous Feb 16, 2009
    yes I have the same problem
  • jakolis Feb 18, 2009
    Yes I downladed a driver installation exe file from web for my sound card and when I run the exe file I get the "this program is used internally by packagefromtheweb" error.
  • dude dude Mar 03, 2009
    I have the same problem, but not with that exact sound driver. How can I resolve the PackageFromTheWeb issue?
    Sergeant:
  • 183 Answers
Download from here http://driverscollection.com/?H=7540&By=HP&SS=Windows%20XP
Latest driver for this model.
Thank you,
note: do not forget to rate this answer.
Posted on Dec 31, 2008
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
Tip
What to do when no audio/sound after computer reformat
Normally, when you buy a computer, whether desk top or lap top, there's an installation disk that accompanies the unit. This is a moterboard installaer. all the drivers needed by the motherboard is in this disk, but most of the time, the retailers will not give this to you unless you ask for it. This is needed to ensure that the right drivers installed will be compatible with your motherboard, especially during formatting or re-formatting prcess. So if you have recently formatted your computer and there's no sound you can just install the motherboard drivers from the installer then presto, all your needed drivers are installed. But if you don't have the installation disk or mis placed it already, then use the following tips to troubleshoot your audio problems. I hope this will help.
Tip #1. Before formatting your computer, whether a desk top or a lap top, make sure to back up your drivers using programs such as "driver genius", "driver checker" or "driver magician" . These programs can be downloaded freely from their respective sites as "Trial Versions". Download and install any of these programs. Any way, although it's only a trial version, you can use all the function of the program, especially the 'back up driver' function. Make sure to back up your drivers to a location not to the disk/drive that you are going to reformat, otherwise it will be erased during formatting. Use a removable disk/drive or USB to back up your drivers. You can now reformat your computer. After reformat, try to check if there is a sound coming out from your speakers. If no sound is coming out then there must be a problem with the audio drivers. To make sure what is causing the problem, try the following troubleshooting guides ; 1) Click 'start', then 'control panel', double click 'sounds and audio devices', if it says that there is no audio device present, then the problem is on the multi-media device driver. 2) If there is a mult- media device present( ex.AC 97), then the problem is on the audio driver.Whichever the case maybe, double click the 'system' from 'control panel' then click the 'hardware' then 'device manager'. From the device manager, click on the sound, video and game controllers. Right click on the audio device( ex. realtek audio), then click update driver. The hardware & update wizzard will appear, click on 'install from a specified location', click 'next', then specify the folder where you stored your back up drivers, specifically your audio device driver, click 'ok' then the old audio driver will be re installed. Try playing a sound from your computer after reboot.
Tip #2. If after trying the first option and still no sound is produced, try to re install your old drivers using the program you used to back up your drivers by using the 'restore driver' option. make sure to specify the location of your back up driver when prompted. After re installing re boot then play a sound.
Tip #3. If upon restoring the back up drivers, still no sound is produced, go to the windows update using internet explorer browser. After checking your system for critical updates, a run down of updates will be posted, check if there's an update for your audio device driver, select he update then click '
ok'. Re boot your system then play asound.
Tip #4. Before doing all the other tips make sure to check if your connections are in tack, sometimes the problem is only a loose connection of the speaker jacks, or for lap top make sure that your speakers are not in a mute mode or off position.
on Aug 24, 2010 | Computers & Internet
Sound card driver problem
First you need to identify the sound driver, for that you need to download the application ASTRA 32 from (http://www.astra32.com/download.htm) run the appliction it auto detects your sound driver,
Then you can copy and past the name and version of your sound driver in google search and download it from the suitable website and run it ,
Best of luck
Regards'
Shib
Mar 30, 2010 | Computers & Internet
I lost my mercury pi945 gcm sound driver...
1. Download the driver from here by clicking on your relevant operating system ie - Windows XP and save it somewhere easily accessible like the desktop.
2. The file is saved in a .zip format you will need Winzip to open it if you don't already have it. It's a free trial if you download.
3. Double click the saved file and extract to somewhere like the desktop.
4. Once the file is extracted, double click it and navigate to the relevant folder ie - PCI or PCI(E)xpress.
5. Double click Setup.exe and follow the on-screen instructions.
6. Reboot the pc.
Feb 01, 2010 | Mercury P4VM800M7 Motherboard
My Dell 720 printer won't work withmy dell 1521
All printers are compatible to a degree.
What operating system are you running on your dell 1521 laptop? What drivers are supported on your Dell 720 printer?
If you are running Windows Vista on your laptop and there are only drivers for your printer up until Windows XP and nothing is on Dell's website for your printer in terms of drivers, then you can only try to run Windows Vista in Compatibility Mode.
If this doesn't work, then you'll need to get a new printer.
Aug 19, 2009 | Dell Inkjet 720 Printer
No Drivers for my Sahara N1356 Laoptop
I couldn't find the drivers for your laptop. Old forums where there people who found compatible drivers posted links that are already inactive. I also tried to connect to sahara's ftp site but i couldn't get in.
you may want to contact their support to get drivers for your notebook. http://sahara.co.za/
you may also try this utility as it scans your pc and installs necessary drivers: http://drivers-download-driver.com/tag/index_244.html
hope this helps.
Jun 26, 2009 | Dell Dimension 8300 PC Desktop
I NEED SOUND FOR MY PC.
Install PC wizard address below. Run & find out your sound driver number.
Visit that supplier's home page search for that driver.
Install.
If you can't get it visit Driverguide listed below. Become a free member & download the driver & install.
I was in a similar situation,& was helped by a kind supporter in What the tech.com.That option is also available.But it takes 2 / 3 days before u can run it. Best of luck.
Source(s): http://pc-wizard-2008.en.softonic.com http://members.driverguide.com/driver/
http://forums.whatthetech.com/
Oct 01, 2008 | Computers & Internet
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
No audio device in the system
i was unable to get the driver for my pc (ie . wizard m558)
Jul 03, 2008 | MTX Audio TXC6.0 Component Speaker System...
Microsoft Windows XP Professional for PC Logo
529 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
