Question about GE JBP82 Electric Kitchen Range
Oven Door Locked
After a self cleaning, my oven door won't unlock. I have done the standard cicuit breaker test and tried to self clean again, but no luck. Is there any way to unlock the door to use my oven until I can afford to have it repaired? Thanks................
  • Thomas11 Dec 02, 2007
    We shut the breaker off and turned it on and reset oven clean cycle still not opening
Try resetting theclean cycle. Hold the door handle a little ajar. It won't open of course so reset the clean cycle then press cancel.  This may do the trick
Posted on Oct 13, 2007
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Oven door locked
Many Kenmore ovens have a control lock that keeps the oven door locked even when the self-clean cycle has not been in use. This feature is meant to prevent children from opening the door or using the controls on the oven. To cancel the oven lockout, push and hold "Stop" for three seconds. Wait 15 seconds for the oven door to unlock automatically.
Reset
After verifying that the oven lockout feature has been released and waiting at least an hour after a self-clean cycle, if the oven door remains locked, try to reset the oven. Disconnect power to the range, and wait 30 seconds. Restore power and try again. If the door remains locked, disconnect the power and try to reset the circuit breaker or fuse. Contact Kenmore if the door remains locked after both attempts at a power reset at 800-827-6655.
Feb 26, 2014 | Kitchen Ranges
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Mar 07, 2011 | KitchenAid Ovens
The oven door remained locked after self- cleaning. Ran the cleaning cycle again it still stayed locked. Also tried throwing the breaker.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | Magic Chef Microwave Ovens
GE Electric Double Oven Door Will Not Unlock
heatman101
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
May 11, 2008 | Ovens
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
GE JBP82 Electric Kitchen Range Logo
178 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
