Question about Apple iPod nano
Data lost in usb after moving from harddisk
i am providing the steps followed that resulted in this issue.
1) inserted pen drive in pc. after recognising, it prompted to restart BUT i didn't restart as some important work was going on.
2) MOVED the neccessary files from hard disk to pen drive.
3) later on another pc i could not find the files moved in pen drive. i could however only see the empty folders.
4) when i checked the disk usage of pen drive it showed the moved content size but i cannot see them inside the empty folders.
5) i tried couple of recovery tools but could not locate the necessary files on the hard disk and also on the pen drive.
is there any way to associate the raw files not seen in pen drive to the respective folders. or any way i can recover the files either on hard disk or pen drive.
thanks in advance.
  • 281 Answers
Update Your Windows Operating System.
Check your computer.
with antivirus and antispyware program.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
3.b) Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to recover data from Pen Drive
Pen Drive gives ussignificant convenience in today's business life. However, due to human errorsor other reasons, we often meet embarrassed phenomena of losing Pen Drive data. The following are sometypically cases in our daily business life.b>
Practical cases:
1. Pen drive still contain all data, and the space shows the same likebefore, but all files and folders in the pen drive are changed to shortcut.
Your pen drive was attackedby virus
Resolution one:
If you oftenuse Pen Drive to transfer data from one computer to another, make sure thecomputer is well protected. If any computer is not protected against virusattacks, the files and folders in Pen Drive may be gone or just change intoshortcut. If that happens, don't panic, you can still get back lost data, Firstly, remove the virus, connect your Pen Drive to one PC that is protectedwith a good antivirus and then scan it, fix all the virus threats that aredetected by the antivirus, After completing scanning, some of the useful filesor folders may deleted. Secondly, use pen drive data recovery program torecover deleted infected files.
Resolution two:
If you can'tdelete virus in Pen Drive, just format Pen Drive and then use data recoveryprogram to retrieve data.b>
2. When transfer files from Pen Drive to PC, mistakenly removed the PenDrive from USB port and some data lost, or press "format" command during theprocess of using Pen Drive. Sometimes, delete data in Pen Drive in one day andfind it is useful in another day and want to recover them.
Human error
The data youonce have saved in your pen drive is real hard to remove completely. Firstthing to do is stop using the Pen Drive as the chances of your data beingoverwritten increase as time goes on. Then choose a perfect data recoveryprogram. There are many Pen Drive data recoveryprogram in the internet. Although Ihaven't tested them one by one, Card Data Recovery is the most popular one inthese days.
Steps to recover data fromPen Drive using Card Data Recovery
Plug the Pen Drive into yourcomputer using USB port;
Download Card Data Recoveryand install it on your computer;
Check whether your Pen Drivedisk display in your computer;
Select your Pen Drive;5. Run Card Data Recovery andcontinue the operation under the interface instruction.b>
on Jul 20, 2011 | Computers & Internet
Removing Write Protection
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
How create a bootable pen drive in win 7
hi ashok, i am happy to help you, just follow this steps
Procedure : -
1. Insert your USB flash/pen drive to your system and backup all the data from the USB as your USB drive will be formatted during the process.
2. Now download WinToFlash tool (free) from here.
3. Run the tool, and browse to your Windows 7, vista , or XP DVD files (make sure that your USB drive letter is correct).
4. Click Create button to begin the bootable USB process. Wait for few minutes to see the bootable USB.
5. That's all! Good luck
Jan 21, 2011 | Computers & Internet
How to connect my samsung GT B-3310 in computer?
To connect Samsung GT 3310 to your computer follow the below steps
1) Connect your phone to your computer using the USB data cable that came with the phone package.
2) Now Insert the software CD that came with the phone in your computer's CD/DVD drive and run the setup file if "Autorun" pops up or browse to your CD drive and run the setup file found inside.This should install all the necessary software such as 'Samsung PC Studio' (or) 'PC Sync' and drivers for your computer to detect the phone.
3) Now find the shortcut to 'Samsung PC Studio' from your desktop and double click to open it.Follow the instructions on the software to detect and connect your phone.Using this software you can organize or sync your phone's content such as contacts etc..
Now all you want to do is to move files such as pictures and videos between your phone and the pc,then
you can do so easily by using the 'Mass Storage Mode'
1)On your Samsung Phone,go to 'settings' menu and then 'Connections' and set the connection type to 'Mass Storage Mode'
2) Now connect your phone to your computer using the USB data cable provided with your phone.
3) Now the phone will work like a USB Pen driver when connected to computer,A pop up will open
on the computer asking you to open the folder,click yes.
4) If u didn't get get the popup then go into Start > My computer,and now you should see a new drive in your computer,it will look similar to the one you get when you insert a Pen Drive.Note that you will get two new drives if you have a memory card inserted in your phone.
5) Now open the drive and browse to the folder where the files are saved in your phone,usually
it will be under the folder named "Pictures'.If you have memory card inserted then check the second
drive also.Once you found the files you need,move them to your computer by simply copying and pasting the files to your computer hard drive just like you would do with any other file.
Hope it helped,thanks for using Fixya!
Dec 11, 2010 | Samsung B3310 Cell Phone
I uninstalled the driver from my transcen jf v30 4gb pendrive. Now windows says hardware not recognized.
Hi s8vysakh6 ,
I would suggest you to try the following steps:
Step 1: Run the fixit provided in the link below.
Check if the issue is resolved
Step 2: Connect the device to a different USB port\ and also connect the USB pen drive to another computer to eliminate issues with the pen drive itself.
If the issue persists,
Step 3: Reinstall USB controllers.
First, please disconnect all USB devices and then perform the following steps:
1. Click "Start", type in Device Manager the Search bar and press "Enter". Click Continue if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows vista will reinstall all USB controllers automatically.
Step 4: Update the motherboard driver to the latest version.
Note: Please check with the motherboard manufacturer before installing the driver.
If the issue persists, you may want to check with USB pen manufacturer for any unknown issues.
Hope this will help !
Mar 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Oct 02, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Pen drive insert disk problem.
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
May 25, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Pen drive
Hey There,
You are getting ur problem because ur WIN32.EXE Application is not wrking properly. To repair or come over ride of this problem is
You need to restore your system using System Restore tool. Follow The following Steps to Restore ur system:
For restoring your system do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that is available, remembering ur system was exactly what you wanted for (choose the point remembering, at particular point ur system was good and wasnt giving u any error while u install any software).
3. Select that restore point by reading the description (The software you've had installed).
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
Gimme your Acknowledge by rating me.
Jan 06, 2009 | Electronics - Others
Apple iPod nano Logo
93 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
