Problem with my GE profile Harmony washer
The message i am getting when i push the 2 bottons is The clutch is not mechanically engaging with the basket properly.. I am very short on cash so if there is a way to fix it with out buying any part i would be very happy. the screen displays a problem and will not let the me push any other buttons, i unplugged it , but it still won't close down the screen.
  • 15,935 Answers
It appears your clutch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
undo the main bolt under the washer pull of the brake hub undew 5 0r 6 bolts and undo 2 plugs there are coil magnets i say about 20 clean them with air and use fine grit sandpaper on the end and inside the brake drum tri that it worked for me
Sep 07, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Ge profile notice: a problem has been detected with this unit
hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is mnunocortes@hotmail.com Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Feb 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Clutch not egaging with basket for my profile harmony washer
If you are getting the message " The clutch is not mechanically engaging with the basket properly " the service manual says to check wiring connections, clutch motor or inverter board.
I rarely see a wiring issue. I'd check the clutch arm and clutch coupler too. They are nylon parts. I'll send you a couple pages from the service manual as soon as I get a chance to scan a few.
Nov 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Reset the washer
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Aug 21, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony Clutch probs./Invertert PCB history
Your inverter board is operating 7 degrees over the max temp...
Clear this error be exiting the service mode and run set up ...
if it comes back you will need to replace inverter board....
let me know if you need more help...
Jul 30, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony 4.0 -Broken Clutch Coupling
if your under warrenty always call for service repairing it yourself voids your warrenty
Jan 15, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Hi: Replace motor asm w/clutch part no. wh20x10024
 If you can put the washer to its side on the floor, check if the small white motor turns when you press start cicle.
Oct 01, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
