Question about Gigabyte GA-965G-DS3 Motherboard
Connecting my power button to mobo
Hi got a new case for my christmas, i have fitted everything correctly however i am unaware where to fit the power switch cable. some help would greatly be appreciated. thanks
    President:
  • 2,110 Answers
Can't plug in power on button cable to new motherboard
Look closely at the new MOboard silk screened lettering to find where the power button wires and the leds go. They're there, just might be in a different place.
May 09, 2017 | Acer Aspire AM1610-U1201A PC Desktop
Hi, I have an asus p5gl mobo, my problem is it sometimes dont turn on. I need to unplug the power supply connector to mobo then on it again, some time it will last for 2 days some times 1 day. my power...
Hello Ncp, hi, there are several reasons why this things happen, here are some possibilities, 1. your motherboard is bad or something is making it bad, (are there holes on the back of your casing where a small RAT could fit in, they sometimes pupu on your mobo, so a visiual inspection will reveal it.) 2. beside the motherboard, are there video cards, or expansion card on your mobo, check them also for this rat pupu (rat waste) 3. your power supply is bad, you have no choice but to replace it with a new or good one. Thats it, keep me posted.
May 04, 2010 | ASUS P5GL-MX Motherboard
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a packard bell IMEDIA MC 2559 PC The mobo's P/N : PB34316801 I got a new case for my son to build a PC for the first time and we got this mobo from ebay...
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
Feb 14, 2010 | Gigabyte GA-6WMM7 Motherboard
I want to upgrade the motherboard in my Sony VAIO VGC-RC110G PC Desktop. Is this possible or does sony use a nonstandard configured motherboard?
Hi:
I have only worked on one of these Sony desktops, and it is really very proprietary, where you would be better off buying a new case to install a new motherboard in. The sony looks really slick, but everything about it is odd: The power supply, the cooling fan for the cpu, etc. It would be a lot easier to save what you can and move it to a new project!
Feb 11, 2010 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
No boot up.
Power supply is easier to troubleshoot my local pc shop has used ones for $5 or if you have one laying around make sure you have one with the proper mobo connector 24pin will sometimes fit 20 pin as long as there are no transistors to close to plug just turn pc off unplug all drives and mobo plug in good supply and turn on if it works thats the problem if not probably mobo
Apr 10, 2009 | Shuttle SK43G (tsk43g) Barebone
T2893 desktop did not power on when I hit the power button
If you can find someone that has the same model, that is the best way to make sure it fits. Some other motherboards will fit, but you may have to do some work to get them to fit. The best way would be to try to do some research on your particular motherboard (mobo) on the internet. Sometimes it will have a manufacture’s name and model on it, try googling it and see what type it says it is (ATX, mini-ATX, AT, etc). One problem you may have is the power button connectors may not be compatible with your new motherboard if you get something besides an emachine mobo. If you are good at electronics it will not be much of a problem for you.
Unless you get an exact e-machines mobo, your OS will most likely not work at startup. Windows XP does not like wholesale changes like a mobo. When it sees that a major configuration change has happened it sometimes freaks out. Sometimes it will just ask you to re-activate windows other times it gets stuck in a reboot loop. Hard rive and CD rom should still work, provide you do not get too new of a mobo. Older HDD and CD drives were IDE connectors, newer ones have SATA connectors. Unless your mobo and power supply unit (PSU) have the correct connectors you will not be able to use them.
To the poster who asked if it could be anything else besides bad mobo. Yes it can occasionally be a bad power supply unit (PSU). A bad PSU does not necessarily mean no power, just not enough power to run the computer. You can try swapping it out with another one of equal or greater output watts. You can try removing the power connectors from the drives and then remove the memory and see if it changes the boot up procedure of your machine. More beeps, different beeps, no beeps, etc. Add one component back at a time to test. Make sure you get the same results and not just a one-time fluke start up. If a memory stick is bad, it usually is bad. A power supply or mobo can be flaky and fail some times and not others.
Jan 25, 2009 | E-Machines eMachines T3830 PC Desktop
Things to consider when replacing a 5600G case
I assume this is an ATX motherboard. Most cases should work. I think most cases come with a power supply but if not make sure yours will fit. I like cases with at least three drive bays which give room for expansion. The biggest problem I see with switching cases is connecting the wires for power button, hard drive LED, re-set button etc. to the motherboard. Maybe you will get a schematic with the case. Some boards are not marked very clearly in this area. You will need a magnifying glass to read this information on the MOBO. Trace the different colored wires back to the case to see what they do.
Jan 04, 2009 | Acer Veriton 5600G PC Desktop
Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Dec 20, 2008 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
Will not boot up at start
this sounds like a mobo issue .... if the machine has been in service for a while or is in a dusty environment a good internal vacume / brushing to remove dust buildup from the mobo might help.... also disconnect and reconnect the main powwer connectors from the mobo... the power button on the case is simply a contact which jumpers the two pins on the mobo... the actual power switching takes place withing the power circuits built into the mobo... you may also try a mobo driver update if it is available
Mar 29, 2008 | E-Machines eMachines Desktop PC
Gigabyte GA-965G-DS3 Motherboard Logo
62 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
