Question about Electronics - Others
Formatting micro sd card
I have a 1gb micro sd card from my samsung mobile g600 but want to use it in another device, when i try to save files on it it wont do it and ive tried to format with my laptop but it comes back with an error saying that the file can't be formatted
  • chinthaka Jayasinghe
    chinthaka Jayasinghe May 11, 2010
    Have you Tried Formatting the card from the Mobile.
    Novelist:
  • 151 Answers
I'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Posted on Jan 01, 2009
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I have black jack..and wen ever i insert my 1gb micro sd,,it shows storage card not found,,,,so,can you just tel me the way to solve this issue....
Dear,
try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found.
it may got currupt.
or try formatting that memory card through a computer, then insert it..
it may will work, but if not then its time to buy a new memory card as that card is currupt.
regards!
Aug 18, 2011 | Samsung Blackjack SGH-I607 Smartphone
G600 SD Card Support
Firstly, ensure that the memory card is correctly slotted in fully until you hear a faint click. [the card can be removed by simply pressing/clicking it back out again]. the memory card icon should appear at the very top of the phone's screen.
In the event that you have done that, to save files to the memory card, go to:
Menu;
Settings;
Memory Settings;
Default Memory;
Then select which items you wish to be saved to the memory card in future;
For example, select 'Camera', then scroll down to and select 'memory card', and press save.
Do this for each form of media, from the 'default memory' list, that you wish to save to the memory card.
Hope it helps!
Feb 21, 2009 | Samsung SGH-G600 Cellular Phone
Sandisk micro sd card 1gb(SDSDQ-1024-A11MK)
when u connect ur fone, a memory card ll appear in MY COMPUTER
if it does not try installing the cd u got
otherwise some driver problem
Feb 16, 2009 | Samsung SGH-G600 Cellular Phone
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
Nov 24, 2008 | Samsung SGH-D900 Cellular Phone
New memory card
The samsung G600 can take a micro sd card but only up to 2gb!
Apr 15, 2008 | Samsung SGH-D600 Cellular Phone
Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
Sep 12, 2007 | Cell Phones
My New Micro SD Memory Chip
i need help. i insert my lexar 1gb micro sd memory card into my phone and my phone doesnt show that there is a memory card inserted and i have no idea how to work it on my phone. my phone is a samsung blast.
Jul 31, 2007 | Samsung SGH-D900 Cellular Phone
Electronics - Others Logo
1,165 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
