Question about Whirlpool GEW9250 Electric Dryer
Dryer makes a thumping sound like it is out of balance.
My dryer is a front load and is less than 6 months old. It started making this thumping sound and I called Lowe's to talk to a service person, he said it was where the tub was put together and was rubbing. He also said this was normal in the higher priced dryers, but would eventually ware down. I was told when I bought the washer and dryer that they were very quiet, well I guess this was not true. The thumping is getting louder and louder.
  • 115 Answers
If it is less then 6 months old you need to call whirlpool and they will send a tech out
Posted on Dec 31, 2008
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire Dryer GLER642AS3 drum off balance problem...It dries but it's making a thumping noise, I think the drum is off balance.
It is not the drum making the thumping noise it is your drum rollers that flat spots on them.
----------------------------------------------------------------------------------------------------------------------------------ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the lint filter, and the two screws that hold the lint filter housing in place to the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 15, 2011 | Dryers
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Dryer thumping
It sounds like the rollers have gone bad. Its an easy fix. If you like the dryer a repair man can fix it cheaper than buying a new one. you may even be able to fix it. if you go sears.com and go to the parts section and put in your model number you can pull up a diagram to see how to take the dryer apart. you can also order the parts from there too. Good Luck.
Jan 29, 2009 | Dryers
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Whirlpool GEW9250 Electric Dryer Logo
403 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
