Panasonic CT-27SL14 27" TV Logo
John Posted on Oct 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No H/V dedlect, Audio is OK - Panasonic CT-27SL14 27" TV
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Oct 13, 2012
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986711
Points
237762
Check and replace damaged component/s at it horizontal output stage circuit. It includes the Line Output Transformer.
tip
TROUBLE SHOOTING TIPS
NO POWER
Check the fuse F01. If the fuse is open change the fuse after confirming there is no other faulty component.
If fuse is OK the check C10 voltage is normal or not. If its not normal then change BD01.
If the voltage on C10 is normal the check the SMPS switching ICs IC01 and IC02. If found faulty change IC01 and IC02.
NO DIGITAL AUDIO OUT
Check the current digital audio stetting is its in PCM or Bitstream . IF it's in PCM then change it to Bitstream.
If ther is no diagital audio out even after it to bitstream, check the AV receiver settings. If everything is ok there too then check the AUDIO DATA at AIC Pin 4 (for BD)or AIC3pin 13 (forDVD) using CRO. If there is no audio data the change the main PCB.
If the AUDIO DATA id ok then check DIGITAL AUDIO DATA at pin7 of AIC3 if there is no audio data then change AIC3. If its OK, Check 5V at AIC2 pin 14. If the 5V is missing check the power supply. If 5v is ok the change the main PCB.
ANALOG AUDIO MISSING........................
CHECK THE FOLLOWING LINK FOR MORE ...........
Electronics Equipment Repair Center
Dcm292 philips no audio all other functions ok
Check the speaker/s first. If it is OK, check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
2helpful
What type of audio jack rgb/dvi in on rear of lg 50ps3
the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
so LG diagram shows separate audio into Audio in RGB/DVI.
Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
The audio jack would only work with mono plug for audio in, to RGB.
My computer lost sound. Audio driver ok. Speaker ok. volume controls ok. Motherboard: Lenovo, Columbus. Pls. help me! [email protected] thanks.
check for the Audio Output port for any damage. Make sure the speakers are connected to the Green Output port. Reinstall the Audio drivers if neccessary.Try good known speakers if you have one.
Pro 640e
How are you testing the audio out?
Are you using another radio?
If so, are you REALLY sure the other radio is ok?
If the other radio is ok, how do you know the mic is ok? have you tested it with another radio?
If the mic is ok, id have a look at the mic socket to check that all the pins are still there. Then open the radio up and check the socket is still connected to the main board.
Let me know how you get on..
M3ODQ
Not getting audio
Check your receive audio enable.
AUDIO PROBLEM
HAI , YOU NOT TELL AUDIO OUT IS OK ARE NOT. THE AUDIO IS OK OPEN AUDIO CONTROLS ON CONTROL PANNEL AREA.SELECT LINE IN VOLUME ADUJEST THE VOLUME .
START>SETTING>CONTROLPANNEL>SOUND EFFECT MANAGER>LINE VOLUME.
Kenwood ks-122 in-dash car stereo/cd changer
hello chevi1981..what can happen is if whoever installed your system did not run your speaker wires properly eg if they have worn through and touching metal or a screw through the wires ,it can blow the audio ics in unit resulting in no sound.all these high powered units have above ground circuits in the audio stage .to check ,hook up a separate speaker direct to your unit,separate wiring ,if no sound, will most likely be the intergrated circuits..these will have to be changed by a tech as cd players are a beast to work on,also your 2 speaker wires should not touch one another.with your sec code if your have a removable face you may not have a code ,as removing face is your security .hope this helps
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
