Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer is fickle!
My Maytag gas dryer won't dry, but here's the wierd part. Sometimes I will stop the "drying cycle" to grab something out of it and the clothes will be hot. Then a few minutes later it will be cold air again. I have no idea how many times it goes hot, I think mostly not at all. I have checked the heating element. It's good-and was replaced many months ago. I use my dryer even though it won't heat because I have 5 kids and can't afford to have it fixed. I have checked all buttons on the panel and I know I am doing it right-as I have done every day for years. PLEASE! I beg of you help meeee! I am a handywoman but this has got me stumped. Much thanks Howse4u
First thing is to check that the vent tubing both inside the back of the dryer [ the exhaust pipe that is attached inside the dryer ] and the tubing that vents it outside the house are not plugged by lint or ? if it is all clear you have an electrical component problem such as a sensor or valve.Unfortunately you will need someone qualified to diagnose and fix this type of problem.Good wishes for you.Stephen
Posted on May 17, 2007
The gas dryer heats then does not heat. The sensor says 99 minutes to dry close. Tried it on timed heat and it dries then stops drying. Sometimes shutting off completely!
Hello,Cheack to make sure your venting is clean and clear..If its blocked the safty thermostat will shut the heat down to prevent overheating.. If the vent is clean i would check the coils.When they start to fail it will heat then not cycle back on..
Jun 18, 2011 | Maytag Neptune MDG5500AW Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Maytag Atlantis MDG6400AWW, timer stopped working
heatman101
May 20, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Clothes not drying - intermitent
Is this a gas dryer?
what drying cycle are you using?
How long has it been since you cleaned the vent?
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
69 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
