Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Washing Machine is very Noisy when spin
When the washing machine goes into spin it makes excess sound and vibrate strong. The machine stands level. The drum inside seems to be a bit loose and i checked in the back and in the center (bearing) is a movement also. Looks like worn out a bit. It does not seem to be tight enough.
  • 640 Answers
If it make noise like a train coming in on track,,,bad tub bearing,,,do you see any water leaks back there ..on the back tub or on the base of unit...if so seal damage,,
Posted on Dec 31, 2008
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During the spin cycle, machine makes a loud clinking sound and cannot spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washing machine makes a loud noise when it spin dries. what could be the problem? it washes well; the machine does not shake or vibrate during the spin drying; it just makes a loud sound; it never was...
It sounds like the bearings are starting to go.The problem is as it is 6 years old the repair job could be expensive,unless you have an extended warranty.It still might be worth getting a quote off one of your local repair dealerships.
Hope this helps.
May 03, 2010 | AEG Lavamat W1050 Front Load Washer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Hotpoint wf620 aquarius very noisy and not letin any water in
A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
1) Unplug the washer.
2) Look under the washer, and make sure all feet are resting firmly on the floor.
3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
7) If it does, call a repairperson or the manufacturer to ask about solutions.
Thanks for your question
Dec 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine will not spin, it will wash and then make a buzzing sound during the spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Dec 12, 2008 | Frigidaire Affinity ATF7000E Front Load...
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
191 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
