Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture with sound buttons and controller can`t operate tv
When switched on there is a delay on audio to come in and no picture appears and only one channel heard on audio cannot change channel even using both remote controller and manual buttons. the unit is sony bravia v-series..
Change sound setup to dk/bg
Posted on Dec 31, 2008
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
Where did u buy this from? I have not heard of this model yet but I might be able to help.
Nov 08, 2012 | Magic Sing Along Consumer Microphone
My sound isn't matching up to my picture
Some cable service providers have a delay in video and audio. It is most likely an issue with your service rpovider. There is a delay in the video or audio. This is not uncommon with some channels.
Sep 21, 2012 | Televison & Video
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I just purchased an RCA RT2906 home theater system and am experiencing audio delay when switching channels on my Verizon FIOS cable box. It takes 3 or 4 seconds for the audio to kick in each time I switch...
You can try using an optical cable but you will likely run into the same issue. Each time you change the channel the digital stream is interrupted. The HT likely takes this long to start the decode process.
Feb 18, 2011 | RCA RT2910 Theater System
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
