Question about Kitchen Ranges
Neff single oven how to split door for cleaning
Hi I have a neff built in model no. i think is can i split door for cleaning? have removed 2 screws at bottom and front glass swings forward a bit but it doesn't want to release from the handle end and as i can't find my manual i wondered if any tekkies could tell me what is the correct way?thanks mark UK
I have same problem with Neff B1641.
Holding tight at handle end.
Posted on Feb 27, 2010
Display works ok, fan works ok, but no heat. Assume element has gone, can this be replaced from the inside the oven without removing unit from built in housing?
I've never worked with a Neff appliance before, but generally, a firm tug will remove the element and a replacement can be firmly pushed in and all systems are go after that. The built in does not have to be pulled out. I suggest you take a look at the owner's manual or call a repair shop in your area that services Neff. If they have the part, ask them if the element can be remove by simply pulling it out.
Nov 01, 2010 | Neff B1644 Electric Single Oven
Neff ovens does it need to be hard wired or via a 13 amp plug
you dont say what model if microwave most models is 13a supply if single built in oven 13a also ok double oven needs 30a supply/ hope this helps
Aug 05, 2010 | Neff Microwave Ovens
Hi, I have a single built in oven and it does not
Here is the web site for Neff. Surf this site and see if you can find you specific unit. Need model and sometime the serial numbers.
Good luck and hope this gets it done for you.
Oct 22, 2009 | Ovens
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Nov 29, 2008 | Neff B1421 Electric Single Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
My neff built in oven door does not close fully
You probably need to replace the oven door hinges, as the springs are weak.
Jul 16, 2008 | Neff B1421 Electric Single Oven
Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
May 17, 2007 | Neff B1421 Electric Single Oven
Kitchen Ranges Logo
186 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
