Fossil JR8096 Wrist Watch Logo
Posted on Dec 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fossil Big Tic watch
Can set the hours and minutes but how can I set it to the exact second as digital seconds keep going when you pull the button out
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Dec 31, 2008
Anonymous
Expert
Level 2:
Answers
104
Questions
Helped
71606
Points
192
Go to web site they should have directions there
Need owners manual for fossil Big Tic Blue JR 8624
Inside the case back on my JR-7855 is a label with the steps to take to change the batteries. The sticker says to short the pad marked "S1" with the pad marked "+". Keep doing it quickly, then check the watch facelb_icon1.png. You got it right when the seconds start to change on the face.
Here is a view at the inside of the watch. The two points you are looking for are highlighted in red.
Ads by Google
Apr 02, 2014 • Watches
Replace fossil big tic battery
Little battery operates the analog. big battery operates the digital second hand on the fossil big tic.
FOSSIL BIG TIC JR-7849
Use tweesters to touch both "+" and "s2" point can change that.
4helpful
2answers
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
1helpful
2answers
I have a BIG TIC JR-8529. Is this model obsolete? The watch was not working properly (stopping/slowing down), so I replaced the battery. It seems fine now, but still no digital display in the background...
Since Fossil do not list their instructions under model numbers it is difficult to be sure that you rmodel still exists but if you go to their web site for instructions http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
(click on this link to go there) and you will see some instructions for various big tic watches and you can select the one that suits yours.
The only one that I could find that had a single button above the winder used it to cahnge the colour. Pressing this button for 2 seconds will change the colour to "alternating" and the same again will produce a fixed colour. Perhaps this will make the change of display you need.
Often with watches, you need to use a pair of tweezers to short the battery case to the chassis ((often marked "ac"). This seems to be a re-set function, although I have never found an explanation for the need to do this.
If all else fails, look up their contact details and speak to them about your problem.
The hands have stopped on my Fossil Big Tic watch but the digital display still works, like the seconds.
This watch has 2 batteries so sounds like the main one has gone flat and the display one is still going, you just need to get the battery replaced.
8helpful
Big tic no longer changes color
The big tic has two batteries. The battery for the display may need to be changed and the circuit reset. You can then hold the display button down for 2.5 seconds to cycle through the display function.
3helpful
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
5answers
Fossil Big Tic Brown Cuff Watch - Faulty??
Hello, not much help I'm afraid, but I was wondering where you intend to get the replacement battery for the 'tic' part? I'm trying to avoid sending it to Fossil.
I imagine your fault would be covered by warranty, and you get 2 years as well I think?
Jan 11, 2008 • Watches
1helpful
Fossil Big Tic Watch - setting the correct time on the digital display
The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
