Question about Nokia N95 Cellular Phone
Water damage in nokia n95
My nokia n95 has fell in bath tub so what should i do now to turn it on again?
  • 20 Answers
Hey, Matthew here, First thing you should have done is to take out the battary. Leave the phone to dry for 2-3 days. If this still does not work you can get some "dipping alcohol". Still with out the battery dip it into it for about 15-20seconds and leave to dry for about a day- this should work if you took out the bat but might still work even if you didn't. Hope this helps. Matt. PS you can get the alcohol in a harware store or the likes:) Please rate me
Posted on Dec 31, 2008
My nokia n95 2gb water damege now set dead and when in put cherger set heat
try sundry it for days first then couple it back it should work
Mar 13, 2011 | Nokia N95 Cellular Phone
My phone dropped in the bath!
you might have some water damage. take the phone to a repair centre
May 06, 2010 | Nokia E63 Cell Phone
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Kohler whirlpool started on its own with no water in it. We turned it off with the switch and it hasn't happened again. Is there a danger of it starting a fire if we are away from home and it does it...
Most Kohler tubs have a water sensor or water level sensor. Is this an air bath tub (holes in the floor)? or a jetted tub? If it is an air bath, the tub will purge after using it 15 to 30 minutes ater it is drained. If it is programable it will come on every 24 hours if it has been programmed. If it is a jetted tub, there may have been water on the sensor and caused it to start up. If it is a single on/off button the switch could have gotten water and caused it to start up, or there is a problem with the control box. It usually will not start a fire if it comes on, most of the newer pumps have run dry seals. If you leave the house for vacation or weekends, I would advise unplugging the tub or turning off the breaker.
Aug 28, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
My Nokia N95 keeps "freezing up", as in it just wont do anything. It wont even power down using the off button. The only way of sorting it seeems to be to take the battery out of the phone and power up...
Its very hard to diagnose without inspecting the phone. But one thing is water damage. If sure that it is not water then it might be a virus or file corruption. Also try to connect it to your pc and run "Nokia PC suite" with "Nokia software Updater". Can you perform a reinstall of your firmware??
Jun 04, 2009 | Nokia N95 Cellular Phone
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
Nokia n95 8gb
i think after all that you should replaced the mainboard
Oct 20, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
405 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
