Question about Evenflo Discovery
Lost Instructions I'm having a problem with changing the belt straps...I'm trying to put them in the top slots...I'm unable to unhook them
Thank you Noggin. Tearing my hair out before this!
Posted on Jan 10, 2008
  • 944 Answers
Go to this link; https://plweb.evenflo.com/replacement_parts.aspx Enter your model number and date of manufacture and you should be able to get a user manual for your seat. Go to the following link; http://www.evenflo.com/Homepage/ProductList/tabid/203/navid/1/Default.aspx?productid=ecebfdde-1e77-45fa-88c9-b46a09ebf069 And there is a demo video and some other info available for your seat. Hope this helps :)
Posted on May 04, 2007
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How do i take the straps off to wash the cover?
Go from behind car-seat, undo belt on metal hook, then pull through the liner.
There is a hook at top and another at very bottom, just unhook the belt from hook and pull through
Aug 17, 2009 | Cosco High Back Booster 22-200 /22-207
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Car Seat Belt keeps getting stuck
check the adjustable strap then check the spring of the strap .
Feb 02, 2009 | Graco Quattro Tour Travel System
Rear Facing UAS strap can't feed through?
Are you sure you're looking at the UAS/LATCH strap and not the top tether?
Your seats should have a long strap with a hook at each end that goes through the belt path (the UAS strap) and another at the top, for top tethering once you turn them forward facing.
The UAS strap may be hooked onto the sides of the seat or bundled together underneath...take another look at your manual to find out where they store it.
Alternately, install with the seat belt - neither LATCH/UAS or seat belt is "safer" than the other...the LATCH/UAS is just supposed to be more convenient.
Jan 03, 2009 | Eddie Bauer 3-In-1 with Latch
Instructions on how to instal a second hand safe-n-sound car seat
how do i put the straps back on through the cover
Oct 19, 2008 | Baby Gear
Nania 3 in 1 carseat
i have lost instructions for nania 3in1 ihave got all the straps but cant put i t together can i download instructions please help
Aug 10, 2008 | Nania Nuevo 3-in1
Changing a Belt
Take the bottom plate off, the brush roll and belt are there, you may have to take the top off, there maybe 2 screws from the bottom to remove, then on the sides there is a slot for a screwdriver to fit into and pry up then the top cover comes off and you can put the belt on the brush roll and hook it around the motor shaft.
Feb 28, 2008 | Vacuums
Evenflo Discovery Logo
567 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
