Grundig TK23 Problem ? Connection Symbols
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have an old Grundig tape recorder (1960's) which I wish to connect to an external tuner to transfer the recordings to my computer. It has Din plugs with symbols on them, but I don't remember what they stand for! Can you help? One symbol is a double wavy line, like '' = '', but wavy. Another symbol is a square with the right hand edge protruding beyond the edge top and bottom, like a square '' d '' without the long upstroke. Another symbol is like a '' Q '' but reversed right to left. I hope you can help! Thanks very much. Bill Hart (Warrington, Cheshire).
  • 883 Answers
SOURCE: Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
Posted on May 27, 2007
SOURCE: record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Posted on Dec 30, 2008
SOURCE: Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Posted on Feb 05, 2009
Grubhead
  • 5309 Answers
SOURCE: can mp3,ipod connect to philips FW-R7 with cd
All you need to get them to play is a "dock" and a 3.5mm Jack to two RCA phono plugs lead.
The Jack goes into the headphone output and the RCA's go into any spare socket on the back of the unit IE tape/cd.
Infact you just need the lead, plug it into the headphone output of the Ipod or MP3 player. But the dock will keep the battery charged and you get a remote with the dock, so you don't need to get out of your chair, to operate the player.
Posted on Feb 08, 2010
Grubhead
  • 5309 Answers
SOURCE: How to record LP records to CD, using a 1978
All you need to do is connect two RCA plugs into the audio in of your laptop. The two RCA's go into a tape out of the recevier. If your laptop uses 3.5mm plugs for audio conections then get a 3.5mm plug to RCA plugs. See image below.
To record the music and convert it I would get Magix Audio Cleaning Lab, which you can pick up cheap on Amazon.
418f330.jpg The sound will then come out of your speakers on your computer and then you can record it with Magix and convert it with the software to any audio format.
Posted on Jun 20, 2010
Testimonial: "This gives wonderfully detailed info with pictures, which a girl like me needs. Will the sound that comes off my recorded CDs, using this method, sound as perfect as playing the original albums directly on the turntable? Thanks so much!"
Amp works but the tunner doesn't all tubes look ok
Basic fault finding would be good. Check for the correct voltages on the valve bases.
Jul 16, 2017 | Grundig Audio Players & Recorders
Grundig tk5
With a bit of luck you may be able to find some adapters to allow a plug into the Line IN port of the computer.
Here is a site that appears to have the Grundig manual if you register ( its free). There may also be some very knowledgeable people there that you provide the info you need.
Oct 29, 2013 | Audio Players & Recorders
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
Grundig PVR/ Digital TV Tuner with no external antenna?
i am living in a house where i cant place an external antina. is there any reveiver that donot require exteernal antina and we can receive channens
Jun 27, 2009 | Televison & Video
Play & Record VHS through TV Tuner Card
You need to connect the ariel to the vcr, then the vcr to the card, using a male/female fly lead. Then I suggest putting an origional film tape into the vcr, press play on the vcr and then scan in the channels on the card. It should pick up the vcr's output of the film that is playing.
Jun 05, 2009 | HP Expresscard TV Tuner For Windows Vista...
Grundig TK23
Dec 30, 2008 | Audio Players & Recorders
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
184 people viewed this question
 Grubhead
Grubhead
