Question about Toshiba Satellite A105-S4334 Notebook
I have black screen on tecra9100 laptop wen i boot it on
The problem is dat wen i boot it ,it passes d post test bt doesnt open into d window environment.d screen turns black.it complained of bad cmos in d prompt window.
  • Jimmy Howells
    Jimmy Howells May 11, 2010
    Is the screen completely black, or is there something there? I need details. Did you make any software changes prior to the error? What is your operating system Windows 2000, Windows XP, Linux? I will probably have more questions after you answer these. Thanks, nightcloak74
My laptop is stuck on a spinning loading screen. The model is a HP Probook 455 G3 and the laptop has passed an extensive system test.
first off try to pull the battery start computer without the battery if that does not work next try to enter safe mode windows 10 F10 Windows 7 F8 for safe mode. try booting it up to a post screen if that does not work you need the backup disk or the repair disk for that computer 1.follow boot instructions screen will pop up as a post screen select repair computer.if you cannot repair the computer as it says it failed you need to boot from the system disk try to upgrade the system with the disk so you wont loose data good luck please let me know if you need additional help. Best, Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | HP Computers & Internet
After booting up all I get is a black screen
Try this:
If you're booting up the device and it goes thru the Post test and then goes to a black screen this usually means your OS has crashed.
You will need your Operating system or Recovery Disk.
I hope you've backed up your data and files.
Try this:
Windows 7
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-7-startup-repair.htm
Vista:
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-vista-startup-repair.htm
XP:
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
Good Luck!!
Aug 16, 2012 | Compaq Computers & Internet
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
Well wen i select memory card for somethin to install from internet then it is showing me disk application error with two options stop and retry.. Wen i select retry phone got hanged.. N i hve moved some...
The best thing to do is reformatting your memory card. Back up your data first if you have a pc like images and audio files (but the application installed will be lost).
Jun 17, 2011 | Cell Phones
I have an nc 6000 laptop dat show d hp logo wen i turn it on, but d screen goes blank after that, how d i fix this problem.
It seems to be a problem with your operating systems (Windows perhaps).
If you are not an experienced user, have it checked by someone else. The easies way
to check whether the computer is OK is to boot some Linux Operating System from the CD, or at least insert windows installation cd and try to start the installating procedure. You will see the option to repair the current installation.
Feb 28, 2011 | HP Computers & Internet
Black screen
Does it boots windows? If the screen gets blank after Windows booting up, you can try repairign the OS. If the whole unit doesnt boot up, then the hardware must be in problem. Check the Hard disk, the power supply and the RAM.
Thank you!
Sabharish
Jun 04, 2009 | Acer Aspire 5500 5570-2609 Laptop
Black Monitor
Try taking out your battery and leaving it out for 5 minutes.  During boot press F2 to access BIOS to check your default video out source is LCD.  Also try Fn+F5 to change the modes of video after you think windows is all the way booted up.  Does it POST?  When booting does the drives make noise then hear a beep.  If it beeps it passed Power On Self Test.
James Mac
Sep 09, 2008 | Toshiba Satellite A105 Notebook
Acer aspire 3610 not booting pass flash screen and if it does gives an error openning windows
try by changing the data cable and check the jumper setting of the hard drive
May 12, 2008 | Acer Aspire 3610 Notebook
Toshiba Satellite A105-S4334 Notebook Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
