Question about Kenwood KDC-X811
Unit just died (mostly)
I've owned this unit since it first came out, and it's worked fine, until now. It worked fine on the way to work the other morning, but on the way back it did not. The D-mask flips around as it should, but there is no display. The radio plays faintly but you can't change the volume, station, source, etc... I'm thinking it's finally bit the dust, but has anyone else had a problem like this that was able to rectify it? Thanks in advance!
  • 1 more comment
  • Allen Barclay May 06, 2007
    I've torn it completely apart. I read another page where his ribbon cable was bad and he was able to fix it using a conductive pen and some tape. I've also talked to a local stereo shop dude who stated that the cable probably needed replaced. I have it in my hand now and I can't find a damn thing wrong with it. All the traces look good all the way down, but when I look at it through a light and can see areas where light is coming through. Can't tell if it's on a trace or not.
    Probably gonna bite the bullet and send it to a repair shop.....
  • Allen Barclay Aug 26, 2007
    I still have it sitting here in pieces. I found a replacement ribbon cable for roughly $8 but I haven't taken the time to order it yet. Just bought a replacement stereo for now. Got another kenwood so I wouldn't have to rip out the wiring harness.
  • Bigbry05 Aug 23, 2008
    I have the same exact problem. The mask will flip around and the buttons light up but none of them respond. Can't even get the CD in there go eject. Replaced it with a Pioneer unit but would like to get it fixed for a different car.
    Problem Solver:
  • 19 Answers
See if the plan cable that goes to he screen is good
Posted on May 06, 2007
My AC unit just died out of the blue.
Sounds more like a bad breaker possiably not getting power to your unit I would check the breaker first
Jul 21, 2013 | GE "General Electric AEN10AQ 10,000 BTU...
Bcf2000 will not power up
check the main switching ic. might be faulty, could be heating.
Feb 25, 2012 | Behringer BCF2000 USB MIDI Controller
My unit, Kiddi Smoke Alarm Model i12040, beeps once every minute. I've checked the battery and it's above 10v. This is a new unit (date June 2010). I've unplugged the unit, plugged it back...
Have you tried a different battery? Occasionally a battery can read good but die under load. Also use care when replacing the battery. Many devices today specify in small print to leave the battery out for a minimum time period (anywhere from about 15 sec to 5 min, depending on the model). Also, it is sometimes quite easy to reverse the polarity on some of these devices. If all else fails, contact the manufacturer. It's possible the unit itself is bad.
Aug 30, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
I have a 1995 Jeep Grand Cherokee V8. It started as a great running little SUV for me but has recently become the most problematic vehicle I have ever owned. With a new fully charged battery it will start...
Sounds like you covered everything electrically. Did you check the belt to see if it is tight enough. It's been a while since I've worked on a 95, if it has an auto belt tensioner. it could be weak, not turning the alternator fast enough under a load. This can happen and the belt not squeak.
Jul 14, 2011 | 1995 Jeep Grand Cherokee
Brand new machine and the pressure gauge doesn't appear to be working, I've made about 10 coffees over the weekend and experimented with the tamping etc. And the gauge has not moved once? Am I...
It could be a faulty machine, what is your grind setting? Make sure your using the dual wall single cup as a test. Set the grind to around 13 and grind your own beans, don't use supermarket bought beans or preground coffee. Both are garbage.
Also if your using the dual wall basket, make sure that you leave the dial guage in the dual wall setting. Then tamp the coffee so it sits roughly 3-5mm below the rim, this is what I have found is best for this unit.
Then secure group head in to unit, press single cup and you should hopefully get a pressure reading, if it isn't going up you are under extracting and your grind is prob to coarse (correct me if I'm wrong), I've found 13 is not to coarse not to fine. Shouldn't feel like fine sand, when coarse but not powdery.
If the gauge does not move in to the grey area your unit is most likely faulty.
Jun 05, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Hi, my DV9700 battery does not charge, adapter works but does not charge or run the computer on its own. I have had it checked and everything seems fine, they suggest the motherboard but I explained that...
This may sound stupid but try this, for some reason this seem to work on 6 and 9000 units with charging problems.
With the unit running, disconnect the battery and allow the unit to run for 60 seconds, then plug the battery back in, again with the unit running.
Nov 30, 2009 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Sanyo DRW-500 Home DVd Player/Recorder
my drw-500 wont read any disc why its say NO DISC please help
Jul 23, 2008 | Sanyo DRW-500 DVD Recorder
Kenwood KDC-X811 Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
