Question about Epson Stylus Photo 1280 InkJet Printer
Inkjep printer the computer says it cant find the printer. i checked the printer using the printer manual information. the printer works. i uninstalled and reinstalled printer software.it went fine. could i have a bad usb cable?
    Novelist:
    Scholar:
  • 104 Answers
Unplug the printer. After uninstalling the software make sure you delete the printer from Printers and Faxes! Try plugging it up again(don't install back the software just as yet), the New device found pop up should come up! if it doesn't then it could be the USB cable / the USB ports on the PC or the USB interface on the card! If it does , put the cd in the drive and select Install Drivers automatically(if its pops up) Also, Try using different USB ports if the new device pop up doesn't pop up! Test the USB ports by using a regular USB device in the same port you are plugging the printer into! A bad USB cable could be the issue but it can also be something else! You'll need to verify that its the cable, what you can do is try it with a cable that you know is fully functional! If you still don't get a response from the printer and everything else works(i.e. usb cable, usb ports) then it could be the USB interface on the printer! and you'll need to take it to a tech! Hope this helps!! regards, babb
Posted on May 04, 2007
SOURCE:
My printer will not print
Use the troubleshooting guide that should be in your printer's manual. There are many things that could go wrong including how software is working in your computer. There should be a troubleshooting guide in the manual, HP makes many different kinds and models of printers there is not one solution for all. Also check at the HP Support website for further information or assistance.
Oct 21, 2013 | HP Office Equipment & Supplies
I cant get my hp psc 1210 to work with windows vista
The drivers is HP PSC 1210 is included in Windows Vista. It should work properly once you have connected the printer to your computer.
Please provide us information whether your computer cannot detect the printer or it is detected but your are unable to print anything. Giving us more details about the issue you are experiencing will surely help us to provide you the right troubleshooting.
However, you can also check the link below for more information about your printer:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=90764#N221
Thanks!
Sep 22, 2011 | HP PSC 1210 All-In-One InkJet Printer
I cant get my Lexmark x2250 Printer/scanner to connect with my computer. It use to work with this computer and I have checked the usb cables and restarted my computer. Do I need to get some sort of...
What is the operating system on your computer? Make sure to set your Lexmark X2250 printer as your default printer in the Control Panel (for Windows) or in the system preferences (for Mac). If you don't see the Lexmark print object in the control panel or system preferences, you should try to download and install the driver for your printer. Visit the Lexmark website using this link Lexmark X2250 Drivers. Select your operating system by clicking on change OS.
Then click on FILTER.
Click on the complete driver under Recommended Downloads. Download, execute the file and follow the instructions on the software.NOTE: Use the Vista driver in Windows 7. If you encounter any problem downloading or installing the software, please contact Lexmark technical support for additional assistance.
I hope this information has been helpful. Thanks.
Dec 27, 2010 | Lexmark X2250 All-In-One InkJet Printer
Cant get my 1610v to scan. Can't find the
turn on/off, unplug, wait a minute, plug back in, should reset.
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order. go to the scanner settings.
lastly, check make of printer trouble shooting web site for more information. hp has an awesome site for trouble shooting
hope this helps, good luck.
Apr 29, 2010 | HP PSC 1610v All-in-One Printer
I can not get my HP Officejet J4680 Inkjet Printer to work on wireless. Can only use with USB cable. I no longer have my Setup CD. Any suggestions?
First check that your antivirus and firewall software are not blocking the print jobs. Do this by turning off the services for a few minutes. If you can print, check for a setup option of trusted machines. If that doesn't help, make sure you have a strong wireless signal between the computer and the printer with no interference from other appliances (cordless phones, microwaves, etc). Also check your settings to make sure the printer and computer are set for the same wireless network profile and security settings.
For additional information, try the user's manual: http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
I hope this helps.
(I have generally preferred printing with a wired connection (USB) over using a wireless networks. I've always spent more time on printer problems that were directly linked to the network signal loss problems rather than printer issues.)
Dec 05, 2009 | HP Officejet J4680 InkJet Printer
Cant open creative web camera - lost installation Cd
Plug your webcam in and visit this site
http://www.testmycam.com/Hit "Allow" in the top window and see if your webcam works in the left panel
If it does not work here, you know you have a hardware problem ( webcam, lead, USB connection etc) .
Troubleshoot by using something else in the USB port, like a printer.
Try hooking your cam up on a friends computer.
If it does work here - you have a software problem
Download this webcam diagnostic tool and run it.
http://www.download32.com/webcam-diagnostics-d35065.htmlRun through the tests using "next" to move through the pages
It always asks me to Re-boot on the first check.
Act on any information highlighted especially if software like Directx requires updating
If no problems are indicated or have been addressed, try interrogating the information in Device Manager
Expand the 'Imaging' folder in device manager, right click on the text of your webcam. Select 'Properties' and check all the information in each of the tabs.
Update your driver by right clicking the webcam text and select 'Update driver software' Use the internet when prompted
If you are still having problems - uninstall the webcam software - unplug the webcam - restart the computer and download new software from here
http://support.creative.com/Products/Products.aspx?catid=218
Sep 01, 2009 | Creative Labs Vista Webcam
Tryin to use my new dell and cant
You can download the software and drivers from the dell site here. They also have manuals to show you how to use it, etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2009 | Dell 810 All-In-One InkJet Printer
Printer 924 dell cant communicate with computer
cannot comunicate means you have to reinstall the driver again, could be corrupted after the virus, also communication problem could be from the cable you use, check both.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 17, 2009 | Office Equipment & Supplies
This is not working
check power cord. connected right. repalce it by other. if not work the check poer cars in the printer,
Jun 19, 2008 | Office Equipment & Supplies
Printer wont work
I need more information: Type of pc operating system etc type of printer etc If using ip address or usb or parrelle conection etc Steveo
Sep 11, 2007 | Office Equipment & Supplies
Epson Stylus Photo 1280 InkJet Printer Logo
95 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
