Question about Whirlpool Washing Machines
Washing Machine Drum doesnt rotate
I Have a Whirlpool Washing machine model G2PWD2. The drum doesnt rotate though the motor rotates and the belt is in good condition. Any help would be appriciated
  • Whirlpool Master
  • 3,463 Answers
Try this site.
In you browser box type in youtube.com
then in the search box type in whirlpool washer repair
Then click on appropiate video(s)
This should hel p with your prob.
PLz rate this solution.
Thanks.
Posted on Dec 31, 2008
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
How to change a belt on a whirlpool ultamite care plus washing machine
Rear access panel off belt right in front of you. turn drum and pull old belt towards you fit new one by putting over motor spindle first, then feeding onto drum spider as you rotate it. Tension by moving motor on it's bolts (out for tighter, in for slacker) About 1/2" movement in centre of slackest part of belt.
May 19, 2012 | Whirlpool Washing Machines
My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do i fix on a drive belt to a washing machine?
There is a removeable cover at bottom rear of washer..
Undo this, and you will see the motor and belt.
It will be very tight to put on, but this is normal as it is a stretch belt, that is why there is no adjustment on motor.
Hope this helps you .
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
DRUM IS NOT ROTATING, BLOWER IS WORKING AND IS PRODUCING HEAT could i have blown a belt?
Try this first:
Unplug the dryer, reach inside and try to rotate the drum 1/4-1/2 turn, sometimes motors get dead zones in them and this will rotate it out of the zone if that is your problem.
If that did not work then chances are that you have a broken belt.
If you have a front loading machine:
If you remove the front of the dryer, it will expose the drum and the belt, if you remove the drum it will expose the drum rollers, motor, and idler pulley.
I hope this helps
Oct 04, 2009 | Whirlpool Dryers
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No washing
there may be some loose connection between the board and the rotating drum.....try to fix it properly
Jan 02, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
May 06, 2007 | Whirlpool LSW9750 Front Load Washer
Washing Machines Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
