Question about Ariston Technologies LI640S Dishwasher
My dishwasher don't rinse and don't dry
My washing machine (LL 64-S) begin run fine and only wash and then decide to stop - And the let number six (Cristal Care Led) turn on intermitent and don't RISING and DRYING. Thanks in advance. Nelson
  • 944 Answers
Here is the link for the user manual if you need it; http://www.aristonappliances.us/_pdf/manuals/LL64_B-S-W_MANUAL.pdf Check page 13 (pagina 35 en espanol) - there is a 5 year warranty on the electronic components. As Catriver describes, the temperature probe can be moved out of position - you should be able to access it and move it gently back into position. If not, use the guarantee if you can, if not you need to contact ariston for a replacement; This link if the USA is convenient; http://www.aristonappliances.us/5_0_contactus.html If not, please post back with your location in venezuela and we will try to find the nearest service supplier. Hope this helps :)
Posted on Jul 20, 2007
    President:
  • 878 Answers
Nelson, according to the information I have on this model the number six flashing is the code for control board failure or the water temp control (NTC) is defective or not positioned. The NTC sits on the upper right hand corner of the soap dispenser and is hard-wired to the control board. According to this info, if the NTC is defective the main board must be replaced too. Now Im not familiar with this model and what they mean by the NTC being out of position is beyond me. To get at it you would have to remove the outer door panel and outer skin by removing the philip screws on the inside of the door. The outer panel will slide down and off with the door in the upright position. Then remove the remaining screws for the skin and the dispensor will be accessable. Catriver.
Posted on Jul 06, 2007
SOURCE:
Will not shut off when plugge in...will still drain fine when I do plug in
How to Fix a Washing Machine Where the Water Won't Stop ...
homeguides.sfgate.com > Foreclosures > Other Foreclosures
1. Turn on the washing machine, and allow it to fill half full of water. ... Turn theshutoff valves on the cold and hot water supply lines clockwise to run off the water running to the machine. ... Remove it and all wiring connected to the terminals.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - When trying to find the the fault Please bear in. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay before looking any further. ... Washing machine will not drain or is noisy on drain. Generally .... As the appliance goes into to rinse it starts filling, then does not stop.
Jan 26, 2016 | Washing Machines
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How old is the Whirlpool washing maching model # LSQ9549PWO...ser CR3028092?
July 19, 2004. go here and you can tell how old any appliance is by putting in the model,serial numbers and brand name.http://www.appliance411.com/service/date-code.php
Jan 24, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not wash off lipstick, peanut butter, mayonaise, have done every cycle, finally did the power scrub cycle
Welcome to FixYa.
I`ll start by saying the single most important factor in any dishwasher cleaning properly/effectively is the heating cycle.
That being said, my first suspicion is the unit isn`t heating sufficiently.
Here`s what you may be able to do to confirm or dismiss this though...
You`ll need to run a diagnostic program and need an ammeter.
**If you are not capable or have any reservations to doing this, I`d recommend calling in an authorized (B/S/H/ ) Bosch service technician**
SHI/U 68— MODELS
To begin the test program, press the SCRUB WASH and DELICATE/ECONO buttons both in at the same time as you turn the unit on by pressing the ON/OFF button.
The version number of the circuit board will appear in the display, 20, 21, etc.
When released the LED’s for the two programs will begin flashing.
The check each LED press the corresponding program button.
To check the countdown display and refill rinse aid LED
press the REGULAR WASH button.
To start the test program, press the SCRUB WASH and DELICATE/ECONO buttons both in a second time.
When the test program is complete, the countdown display will indicate a fault or combination of faults using the following
codes.
If a combination of faults exists, the code numbers are added together. (6 = faults 2 + 4).
0 = No Faults
1 = Aqua Sensor Fault
2 = Heating Fault
4 = Filling Fault
8 = NTC Fault
**During the test, with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater**
i.e.
If it doesn`t draw any amps. let me know. It is likely an issue with the control that can be repaired fairly easily.
Again though, If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Sep 16, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ariston Technologies LI640S Dishwasher Logo
336 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Håkan Sterner
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
