Question about Bosch Axxis WTL 5400 Dryer
Change hook in the door
Hi, I need to change the hook in the door - how can we do that ?
  • candacebelli May 09, 2009
    door hook snapped off at the thinest part got a new one from bosch but now unsure how to fit. trying to work out how to get inside the door panel to replace the hook.
The front door panel clicks off with the help of a butter knife! then you are able to unscrew 2 fixings with a 5sided star star-shaped key (or in the absence of this specialist a 2.0mm 6-sided hex allen key will do). the broken hook can then be removed backwards out of the door and the new one put in.
Posted on May 09, 2009
  • 148 Answers
You will need to get inside the housing to change the switch. The top typically hinges back then you can get to the front panel.
Posted on Dec 31, 2008
Ford focus ghia mk2 55 reg front passenger door hard to shut,what part do i need
You need to check if the position of the hook is in line with the lock on the door. Also check the door hinges are not playing, if they do, need to change the hinges first
Jan 19, 2018 | Ford Cars & Trucks
Battery draining
That test light method is not a true indication of what the issue is. You need to use an amp meter in the same manner but it has to be able to read at least 10 amps. Keep in mind that if you have the door open on the car that it draws a lot of current.
Aug 09, 2015 | 2004 Cadillac Deville
How do I change the mirror on Dodge Nitro?
You have to start with removing the door panel as follows:
CAUTION: Pay close attention to the plastic hook attachment points on the inside of the door trim panel. Make sure that every hook is correctly positioned to the door when installing the trim panel. Damage to the trim panel will occur if the hooks in the door panel are not properly positioned to the door during installation. 1. Connect the electrical connectors and install the power window switch. 2. Carefully install the door trim panel (4) to the door (1) by lifting upward and over the door lock into the trim panel then attach the trim panel to the carrier plate attachment points. 3. Install the screws (2) and the cap screw covers (3) to the front door trim (4). 4. Install the fastener (5) at the handle area of the front door trim (4) and tighten screw to 5.5 Nm (50 in. lbs.). 5. Install the door handle trim bezel (6).
1. Install the mirror assembly (1). 2. Install the three nuts (2) and tighten to 7 Nm (65 in. lbs.). 3. Connect the electrical connector (3). 4. Install the trim panel
Jul 21, 2014 | 2008 Dodge Nitro 3.7
Change springs on garage door
It's is straight forward. Select a replacement spring with the same tension color as the original spring. The color is applied to one of the hooks. Above all thread the safety wire through the center of the spring.
Feb 02, 2014 | Stanley Hardware 730610 110 Lb Garage Door...
I need to change the door catch, so how i take the door apart to replace the catch ??
if you mean the door hook inside the door this is quite easy you need a flat small bladed screwdriver to split apart the plastic inner part of door from the outer keep working around till you have released all the catches there are several, the inner skin will pull away revealing the hook and a spring the hook just slides out refit new hook with spring and reassemble. easy.
Jun 04, 2010 | Neff H5642 Convection / Microwave Oven
Door can not close perfectly
you can change the top door hinge but make sure you have somone to help you line it up .....
Apr 09, 2009 | 2002 Volkswagen Passat
Hi - I need to change the ink but I am unable to pull the hook to the center of the printer in order to reach the black cartridge
If it doesn't come to the center when you open the ink door, the mechanism is probably broken.
Try unplugging the power cord, see if it will move, then reconnect the power cord.
Dec 09, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Fit door hook on microwave oven
Depends on brand and model, of course, but normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 27, 2008 | Microwave Ovens
LOCKED DOOR (but it's not!) GE JKP85
bob, sounds like the door lock cam is making the door lock switch. Either the switch actuator stuck in or the cam failed to home. The cam has 2 funtions, one is to position the lock hook in the door and the other is to tell the board whether the door is locked or unlocked. On a single or upper oven the assy. is behind the control panel. For lower ovens the assy. is behind the trim between the two ovens....Catriver..post back.
Apr 06, 2007 | GE Profile JT955SFSS Electric Double Oven
Dryers Logo
833 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
