I took the motor of my trolling motor apart. I had an issue getting the brushes back on but figured that out. A couple of the wires came undone and i plugged them back before closing the motor up. Now the trolling motor doesnt work. It makes a subtle buzzing sound in the pedal and the head. one of the wires in the head got hot near a connection. I repaired it. It still buzzes. i can feel the wire buzz. i believe it was the red/black one. What could be the issue? I am going to take the motor back apart and check that i plugged them in the right spots but im almost certain i did. i have tested the outlet and the connections at the board. I get 12 and 24 volts in certain combinations but im not sure exactly what will determine if its working.
My guess is you either have a brushwire against the housing or the leads are on the wrong terminal. the red/black goes on the same as the lower brushwire and the black goes on the same as the upper brushwire. The motor should have a 60A breaker, assuming you have 6ga wire. If wire is smaller than 6ga, the breaker should be downsized. To test the control board, check the voltage in and voltage out. Voltage out should vary as you turn the dial.
SOURCE: Minn Kota maxxum digital control board
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider
the savings that can be had when an informed Expert can save you a $100
service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If
you don't want to pay - feel free to re-submit your question so it
returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
