Question about Acer Computers & Internet
How do I change the account name of my acer bio-protection?
During installation I must have put my password where the account information was to go. So now everytime I open up the system settings to use the protection, my password is on view... how can I change this?
thank you
  • gencymer Jan 01, 2009
    To Murdock_4, yes that is correct, the username was intended to be my password. I'm running windows Vista Business.
    To Ihurry, it's not the user name for my pc but the username for Acer Bio-Protection Fingerprint application which came pre-installed on my pc, I just had to fill in the fields to activate it.... and must of filled them out wrong. Now the user name is appearing as my password.
    It is however connected to my user folder as when I look in my C drive/users, it appears as the password name and not the user name I gave my pc (which appears in the users in Control Panel)
    any suggestions?
  • Murdock Grewar
    Murdock Grewar May 11, 2010
    re you saying that your username is your intended password?
    Which version of Windows are you running?
    Problem Solver:
  • 6 Answers
Try going thru control panel click on users and edit that users name to display proper name and change password
Posted on Jan 01, 2009
    Problem Solver:
  • 12 Answers
Hmmmmm.....
If the folder in "C:Users" is the intended password, I would have to agree with lhurry. If changing the password and username through the control panel does not solve the problem, then
"Acer Bio-Protection Fingerprint Application" must somehow have a higher authority than the administrator.
If this is the case, I can't help you too much without some research on both ends. I strongly reccomend, though, that you try the following:
  1. Try changing the username and password through control panel.
  2. If it doesn't work, make sure you're using an administrative account.
3. Go into the "Acer Bio-Protection Fingerprint Application" and see if there aren't options (Probably under Tools > Options) that allow you to re-enter some or all of the problematic settings.
4. If all else fails, http://www.google.com/.
Posted on Jan 04, 2009
Acer 5315 laptop
did you assign a password ?
try just clicking in it or type in administrator for the id if this fails
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
hope this helps
May 11, 2012 | Acer Computers & Internet
How to reset user name and passwords on xp
also
if you decide to install a bios password
write your bios password down and keep it separate to your computer in case of memory lapses
hope this helps you
Dec 10, 2011 | Dell Dimension 8200 PC Desktop
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
Jun 12, 2011 | HP Compaq 6730s Notebook
Password forget..
remove the baterry for 20 minutes to loss all bios save input then put it back and open your computer this will back to default setting
May 30, 2011 | Acer Computers & Internet
Becouse i dont remember my new password..plz help me becouse i dont open my fb..thank you..
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
there are a number of things that you can do to remove your password another option would be to remove your cmos battery Hope this helps
Apr 10, 2011 | Computers & Internet
Brendella@ charterForgot password on Acer Netbook....ASPIREone. How do I change it and I want to change my uer name?
a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
once the battery has been removed an alarm could go off ((dont be alarmed))
hope this helps
Jan 27, 2011 | Acer Computers & Internet
I don't have the password and i want to go in bios
if you have not assigned a bios password or anyone else has you do not need a bios password to enter BIOS
also
hope this helps
Jan 21, 2011 | Acer Aspire 1360 Notebook
Can't remember my startup password.
When you boot up to the log in screen type in administrator to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings
or
also
hope this helps
Jan 06, 2011 | Acer Aspire 5315 Notebook
I have forgot my password for my computer and cannot access as the administrator only can access my daughters account which has limited privleges
When you boot up to the log in screen type in administrator to log in if you cant log in
or
hope this helps
Dec 07, 2010 | Acer Computers & Internet
Restore my Acer Aspire One AOA110-1588 PC Notebook
Do you mean that, in system information the users name is name after your friend?
Goto control panel, goto system,goto advanced system,click computer name, put the name you like click change and then click ok.
Changing user name- goto control panel, goto user accounts select create a new user account or manage another account fill the blank except if you don't want to password it, set it as administrator if everything is done, log off then log to the created account backup the files from the other account. Then delete the account of your friend under User Accounts. The only thing left will be name to you. Except some other name he/she change in registry like registered name.
Hope it helps
Apr 13, 2009 | Acer Aspire One AOA110-1588 Notebook
Computers & Internet Logo
1,461 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
