Cars & Trucks Logo
Posted on Dec 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car wont start immobiliser not working
I have a 1993 subaru impretza recently the battery went flat because i left the interior light on. i have recharged the battery and now when i try to enter the pin code on the sigma alarm keypad my code does not work. i have no idea what model alarm it is also i dont have a manual as i purchaced the car second hand and none of this information was passed to me. is there anyway to solve this problem?
Anonymous
Level 2:
  • Expert 507 Answers
  • Posted on Oct 30, 2009
Anonymous
Expert
Level 2:
Answers
507
Questions
0
Helped
187115
Points
957
You need master code through subaru,quote Vin no (chassis ) to them and you may need proof of ownership like rego papers,
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2008
SOURCE: i have a 1993 subaru
reverted back to factory code try internet for codes or get it unlocked from a car audio shop
Changed light bulb on 1993 subaru impreza now car won't start, everything lit up on the dashboard
1993 Subaru Impreza Won't Start! - NASIOC
forums.nasioc.com > ... > NASIOC Technical > Service & Maintenance
Sep 12, 2004 - 3 posts - ‎3 authors The car has been running fine, but recently in the morning especially, it won't turn over. I crank it and its trying to start, but there is no spark. Car won't start, cranks but no start. - NASIOC - North ...
Aug 26, 2013
car wont start, getting fuel and spark - NASIOC - North ...
May 22, 2012
HELP: Car won't start after timing belt change - NASIOC ...
Sep 23, 2008
Weird starting problem--1993 Impreza - NASIOC ...
Mar 4, 2003
More results from forums.nasioc.com
my 1993 impreza wrx wont start please help - ClubWRX.net
www.clubwrx.net/.../134323378-my-1993-impreza-wrx-wont-start-pleas...
Dec 5, 2009 - 7 posts - ‎2 authors can anyone help me, my 1993 impreza wrx wont start, 2 days ago i went to ...ClubWRX Forum - Subaru Impreza WRX and STi Community and ...
I have an audi 80 convertable petrol on s reg
Sounds like a security problem. I had my mechanic by pass mine as it was cheaper that way. No problem now.
1helpful
Replaced battery on my rav 4 and it wont start, central locking also wont work
Dose the check engine come on with the key in the start position?
Do i have an immobiliser problem?
Take a close look at those two lights. If one is a "check engine" light the car should be scanned. Autozone, Advance, and Oreilys do it free.
Some cars have switches on brake pedal levers or clutch levers which must be coordinated or timed to INTERLOCK with the starter. Also gearshift must be aligned similarily, such that all switches must be lined up for starter to work.
If lower switches are knocked out of position by feet, then it can cause starting problems.
Check your Battery voltage. Some antitheft are very sensitive to low voltage and the immobilizer will kick in.
How to disarm the immobiliser on rover 200
Is the key fob battery flat? If so fit new CR2032 and re-sync to car by pressing lock 4 times in succession
I have a 2000 Subaru Outback and recently the ABS light came on while driving out to my parents'. When I got there, I called our mechanic and made an appointment for later in the week to have it...
Here is an idea. Check the connections between the battery and the car's ground and the starter. Then find the ground cable which connects the engine to the car and check the connections there as well. Often times odd ball electrical problems are caused by a faulty ground, especially when there is a starter issue. May help, costs nothing but a few moments of your time, and once in a dozen times it is the problem.
I have recently bought a 1993 520i which wont start. the ignition turns on but the engine wont turn over/start, it is not the starter motor as the car wont start on a bump either. I have narrowed the...
IF the solenoid which activates the starter is not working, you would not be able to get the car to start with jumper cables (bump ?)
So the problem could still be starter related.
There are a lot of questions on FixYa about 'theft/immobilisers' and not a lot of answers.
I hope yours is starter related.
2helpful
Inertmitant low idle after flat battery
Hi there am having same problem with my 2001, did you find anything out. also when I go up a hill it trys to sputter out on me, never on the flats tho.
1helpful
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
