Question about PfaFF Creative 7570
Pfaff smart 300e Embroidery machine
Posted by Lydia105 on Dec 31, 2008 Machine mode indicator shows "U00" and every light is on. The machine will not respond. I tried to do a de-frag when it locked up. What do I do? I have tried everything I know how to do. Please help! Lydia
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Jan 03, 2013 | PfaFF Creative 7570
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Does Pfaff have any Disney fantasy cards for the 7570 embroidery machine
no brother has exclusive rights to disney designs look for brother 780d embroidery only machine as cheepest option
Mar 19, 2011 | PfaFF Creative 7570
Does this machine have a low shank --- or high shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop
Bargain Box
Apr 19, 2010 | Janome Memory Craft 9000 Computerized...
Is this machine a high or low shank? I'm trying to buy a 1/4" quilting foot or seam foot and not sure which foot to buy.
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Nov 12, 2009 | Janome 8080 Computerized Sewing Machine
S. It displays an error code of U00.
I use window xp.
I cannot send design to machine .
I open white program but it show " an unnamed file contains an
invalid path"
My computer can connect machine. but not send design to machine
Jan 01, 2009 | White Sewing White 4400 Computerized...
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
221 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
