Power switch at the front of the computer only flashes briefly when depressed, Computer wont come on. This is an intermittent problem but most frustrating. It may sometimes take a day or two before the switch will work correctly and the machine will turn on.
Suggest;
1) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your unplugged from power computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
The front of your computer is the Front Panel. The area of contact pins, that the main wires from the Front Panel go to on the motherboard, is the Front Panel header.
There are two contact pins that the Power On switch wires connect to.
I would like you to jump across those two pins, and see if the Power Supply comes on;
Gateway Support > GT5404 Desktop PC > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2916
Click on the Support Documents tab.
(Driver / BIOS / Applications / Patches / Support Documents / etc)
Click on -> 1009371 - Support Documents
Click on Components in the list.
Scroll down to the Motherboards subheading.
Click on the blue -> 4006158R - Intel (Coryville) 945G Motherboard
In the list click on Product Views
Click on O - Front Panel Connector (Front Panel header)
Pins 6 and 8, which are the two pins in the Red areas, is for the Power On switch.
http://www.directron.com/atxswitch.html
The above ATX power on switch is used a Lot.
It is inside the plastic Power On Button assembly.
If this is the correct style of Power On switch, and yours is bad, you can use a hair dryer to gently soften the plastic of the Power On Button assembly, and replace the Power On switch.
Do Power On switches go bad? Yes. A LOT.
Those who do not know how to diagnose usually wind up replacing the motherboard, or Power Supply.
For additional questions, or to have me clarify any of the above, please post in a Comment.
Regards,
joecoolvette
SOURCE: hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
SOURCE: gateway gt5648e desktop power
I had temporarily solved this problem on my PC. After much research I've learned that Gateway shipped these PC's with faulty bios. What you will notice is that your machine will "loud fan reboot" every hour like clock work. Either clock in manually or use your system tools to see the exact reboots and manually reboot a minute before it shuts itself down. This has worked for myself and many others on various boards if you google the problem.
Weird? Yes!! But it worked !!! 2 months reboot free.
SOURCE: gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
SOURCE: Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Hope this helps.
SOURCE: My gateway gt5404 says no rgb signal what do I do
With 3 beeps, you are getting a Memory base read/write error, which means your RAM is having a problem.
You can try takng the RAM simm/dimm out and re-seating them back into the slots.
If the issue continues, you will need to replace the bad RAM
