Question about Bogen Communication Bogen Manfrotto Tripod 351MVB2 Pro Video Aluminum W/503 Fluid Head
Problem removing head from tripod
I just got a 351MVV tripod which should have been MVB2K.  i already put my 503 head on the tripod.  now, i can't get the head off so i can exchange the tripod.  i only hand tightened the head.  please help.
  • cynthiagranv Jan 03, 2009
    thank you...eventually i was able to remove the head by engaging a lock latch on it...while the screws are mentioned in the instructions and i had tightened and loosened them appropriately, the latch was not mentioned in this context.  with the latch unlocked, the head swivels, making it difficult or impossible to get it to unscrew from the tripod (the head's just turning, not unscrewing).
    Novelist:
  • 121 Answers
Look on the underside of the platform where you screwed on the head. It should have 3 small screws in it. These are tighened and loosened with a jeweler's screwdriver. You may have one screw that is just *barely* tight, so you were able to hand tighten the head until it "locked" into place with the screw. When you loosen each of these screws a few turns the head should come off.
If you can't locate these screws, or you can't remove the head, you will need to take the tripod to a large camera store for assistance. Their rental or repair department can help you remove the head. If you need help locating a large camera store with a rental or repair department in your area, I may be able to help - I would need your location (e.g. city/state/country/zip or postal code).
Posted on Jan 01, 2009
Cannot find way to attach new Pistol Grip head
Often the less expensive tripods do not have heads that are removeble and replaceable. On the Sunpak 6600DX you have teken the head apart, but there is no provision for putting on a new one because it was never made to take one.
Mar 04, 2014 | Sunpak 6600DX Tripod
Will manfrotto tripod mvt502am fit in my MBAG80
It should..., the bag is 80cm long..., the tripod is 61cm when folded & the head is approx. 10cm tall!!!
Math says yes!!!
Jun 21, 2013 | Manfrotto Photography
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
Tripod head
If the head is loose on the tripod follow these instructions:
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
If screws came out elsewhere, we will need to know the model number of the head that came apart.
Jun 01, 2010 | Manfrotto (Distributed by Bogen) 055XDB...
How to remove pan head from velbon 530, it feels very tight
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Aug 10, 2009 | Velbon EL Carmagne 530 Tripod
Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Jun 03, 2008 | Manfrotto Photography
Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
May 06, 2008 | Manfrotto MagFiber 190MF4 Tripod
Tripod head
Not all tripod heads will come off the tripod. some are made on the tripod so if you remove the head, you will have two non functional parts.
Jan 08, 2008 | Photography
Photography Logo
444 people viewed this question
Top Bogen Communication Photography Experts
pontelemon
pontelemon
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
