Question about Bosch HBL 5032 Electric Single Oven
Fan oven not heating, bosch hbn 202t
I switched on the fan oven last night and left it to heat up, about 3 minutes later there was a 'bang' ,the fuse had blown.This morning I changed the fuse , tried the oven , fan working,set the thermostat, just not heating up, I tried the grill, no problem so the element is ok. Just the fan oven does not heat up, any solutions ?
  • 8 more comments
  • Satpal Sahota May 08, 2007
    this oven has only one element,its a single fan assisted oven, bosch hbn202t, any solutions?
  • Satpal Sahota May 10, 2007
    Thanks for your help, did not realise there was a second element, have ordered a replacement.
  • neilyboy Jan 02, 2008
    single built in electric fan oven. fan works and so does grill, however oven doesn't work
  • barryho Feb 13, 2009
    My Bosch HBN 7020 fan oven - fan working but oven not getting hot. Will it be faulty element? Is it easy to change?
  • Anonymous Mar 16, 2014
    Blling B170 G when top oven switch is put to grill position the fan does not run and the grill does not heat up
  • Anonymous Mar 18, 2014
    bosch fan on no heat oven
  • Anonymous Mar 23, 2014
    No heat in the electric oven the fuse box has been checked is OK the light the fan the pezzo all work but no heat in the oven.!
  • Anonymous Mar 24, 2014
    The heating eliment is not working
  • Anonymous Mar 25, 2014
    The oven heats up but the fan does not work on any setting.This oven came with the house we purchased so I am not sure how it should work or what to look for.
  • Anonymous Mar 31, 2014
    EEB9640.0 drop front fan oven
    President:
  • 1,462 Answers
The fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
Bottom oven does not heat up fan works
The element is usually located at the rear of the oven compartment,behind a removeable cover, this is also where the fan is located.
Hope this helps.
Nov 29, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Bosch double oven, fan and light work but won't heat.
my lower oven wont heat on my HBN 70 got light and fan but no heat
Oct 18, 2009 | Bosch Ovens
Oven turns on but does not heat up
If fan is working o/k, then you need to fit a new oven element.
Please rate my solution.
Thanks.
Aug 27, 2009 | Ovens
Tip
Common heating faults with Bosch HBN 131560B / 131520 single oven
on Jan 19, 2010 | Bosch HBN 131560B / 131520 hot-air...
Tip
Common heating faults with Bosch HBN 442 / HBN446 single oven
on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 | Ovens
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Bosch HBL 5032 Electric Single Oven Logo
1,335 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Bosch Oven Expert? Answer questions, earn points and help others
