Question about Microsoft Xbox 360 Console
What does 2 flashing lights mean on an xbox 360?
I have 2 red flashing lights on the left side of the console wat does this mean? and how can i fix it?
    Habit-Forming:
  • 94 Answers
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan. http://www.gamerepairparts.com/xbox-360-cooling-.html
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Posted on Dec 31, 2008
  • Bill Gilhooly
    Bill Gilhooly Jun 06, 2011
    They tend to move things every now and then. Here is an updated link to show an external cooling fan for the xbox 360.http://www.powergamingparts.com/xbox-360...
2 Suggested Answers
  • 1093 Answers
SOURCE: what does 2 flashing red light mean on an xbox 360?
2 red lights is the overheating error, you will need to try and dust out the console, or what you can do is send it in to get it fixed or use a good guide to fix it
Posted on Nov 27, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
2 red lights start flashing
Two red lights flashing on the Xbox 360 means that the system is encountering overheating issues. What you can do is to let your console cooldown for about half an hour and you are ready to go. Also, if you are connected to a Hi-definition output and running on 1080p, you might want to downscale it to 720p as the console generates less heat in lower resolution. Hope this helps..
May 12, 2010 | Microsoft Xbox 360 Console
I have got two flashing green and red lights on my
Either something freaky is happening to your Xbox, or you have the "red ring of death" which mean you'll have to take it to get repaired.
Mar 10, 2010 | Microsoft Xbox 360 Console
Two red lights left side flashing on the xbox consol do you what what the solution is?
hello,
Two red lights lighting up means that your 360 is overheating... try to move your 360 to a cooler spot. you can also try to vent the heat by pointing a desk fan directly to the console.
I hope this helps.
- HotRatchet
Feb 11, 2010 | Microsoft Xbox 360 Console
The x box 360 has 3 red light on.. wat does it means.
If your Xbox 360 has 3 red lights on it it means that you need to get it fixed, it is caused by overheating, you can fix it yourself or send it in to be fixed.
Dec 20, 2009 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
I droped my xbox on the floor
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console is well ventilated by making sure that the console is not in an enclosed space. You may hear the fans operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Sep 01, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
4 red lights flashing
CAUSE This issue may occur for one of the following reasons: The audio-visual (AV) cab... loadTOCNode(1, 'cause'); This issue may occur for one of the following reasons:
  • The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console.
  • The console is not detecting the cable.
This issue does not occur if the AV cable is plugged incorrectly in to a television, stereo, or VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port
Dec 30, 2008 | Microsoft Xbox 360 Console
1 red light
1 red light means general hardware failureand it is pretty much the same as 3 red lights but it is has a slightly different problem. if you are under warranty send it of to microsoft. they will repair it for free. if not buy a new warranty for 60 dollars.
Nov 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
749 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
