Question about Gigabyte GA-6OX Motherboard
Gigabyte GA-60X Memory upgrade.
Hi there, can anyone tell me please the maximum size of memory you can use on this board. the manual states the maximum is 512 SDram 133Mhz but i know the manual is old and will be out of Date.
Any offical suggestions.
Cheers shaun
  • 20 Answers
Hey syconus, Matt here- It will unfortuatly still only take the 512mb because it is not compatible with the new memory. Sorry:|.
Posted on Dec 31, 2008
    Genius:
  • 1,019 Answers
Hi Shaun,
the official site manual, states that 512 meg of sdram. is the maximum.
The latest bios update, was 31-10-2002. this did,nt give any extra support for more memory either.
Largest cpu support is P3. 1.4 gig. i,d suggest an upgrade for your best option. ( boards very outdated )
if the board has 3 x ram slots. you could try 2 x 256 meg strips. and add a 64 or 128 meg strip at best. ensure it,s the same rated ram. i.e 100mhz or 133mhz. it,ll either boot or it won,t.
you can always remove it. and restart the computer.
hope this helps.
Mike @ Compurepair.
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
Swapped in 2 ddr 512 266mhz sticks for, 2 sdram 512 133mhz sticks. no boot, only beeps, neither sticks will work in either slots. cpu has a athlon xp 2000 133mhz processor, is this the problem? Do I need a...
Your motherboard works only with 100 or 133 MHz memory modules.
You hear the beeps because the motherboard is telling you that the memory is not compatible with the board.
The processor is not the problem.
Don't forget to rate this answer if it helps
Dec 05, 2009 | EliteGroup K7VMM Motherboard
I have 512 sd ram but i another 128,128 sd ram do included but its not working how can i solves this problem
The D815EEA2 motherboard only supports 512MB RAM maximum - I'm afraid there is no way to add more to it.
From Intel's description of the model:
Intel 815 Memory: Three 133MHz SDRAM DIMM sockets. Supports a maximum 512MB of 133MHz SDRAM
Aug 10, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Upgrade beyond limits
if you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
Nov 29, 2007 | Sony VAIO Digital Studio PCV-RX550 PC...
Gigabyte GA-6OX Motherboard Logo
667 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
