Question about Insignia IS-LCDTV32 32 in. Television
What kind of capacitors are those?
So I've read that there are 3 capacitors on this powerboard. I've taken the powerboard out and indeed the 3 capacitors on the top are blown. The only markings I see is 680uf 35v 105c. I've called around to see who has these capacitors but they also need to know if they are bi-polar or low esr. I am not an electronics expert so I'm not sure how to test these or figure out what kind they are. Can anyone offer any suggestions?
  • 2 more comments
  • Hoai Duc Ly May 07, 2007
    I looked at the Capacitor again but I don't see anything new. The only markings I've found on it are:
    JH (Manufacterer?)
    CD263
    680uf
    35v
    +105C
    T-5
    Sorry, if I seem like a noob, but in reality, I am a noob at all this lol.
    Whoops, forgot to mention. The powerboard number I got is: KAS200-5S242212XS. I've googled it, but all the manufacters are in China. I've even emailed them lol, but no response yet. =(
  • Hoai Duc Ly May 10, 2007
    Thanks for all your help on this. I still don't see any new clues so I'll just look for Bipolar/Low ESR and hope for the best. I mean, the worse that will happen is the board might get fried? but well.....it wasn't working to begin with. =)
  • Anonymous Dec 21, 2007
    i have the same problem
Another thought in finding the mfg'r for the power supply;
most companies in the US have their products UL or CSA approved. These products have a UL or CSA listing number and
you can call UL to get the MFG'R name ans address from them
under the listed approval number on the board or serial number.
Posted on Jun 05, 2008
I am also holding the same board and can confirm that they are not bipolar. standard electrolytic. the three i am replacing are bulging, but i'm not sure if they were the culprit of the malfunction. they seem to still hold a charge. you can order the caps from mcmelectronics.com
Posted on Mar 08, 2008
I'm holding the same board in my hand and they are not bi-polar.
Posted on Oct 18, 2007
  • 247 Answers
Have another look at the capacitors you've got. If one of the leads is marked as negative (suppose it's possible that the other would be marked as positive instead, but the standard is usually to mark the negative) then you don't need a bipolar capacitor (for capacitors with one lead coming out each end, look for a band round one end of the capacitor with small minus signs printed on it. For capacitors with both leads coming out the same end, look for a stripe down one side). On the other hand, if there's no indication which lead is meant to be which, you probably need bipolar. If your application needs low ESR, then it needs it. If it doesn't, putting low ESR caps in will do no harm other than pushing the price up a bit and maybe having a bigger footprint. A.
Posted on May 04, 2007
  • Alastair Macleod
    Alastair Macleod May 07, 2007
    Have a quick squint at the picture inhttp://xingchen.en.alibaba.com/product/5...
    The sort of marking that would single the capacitors you've got as not needing to be bipolar is the pale stripe you can just see running down the left hand edge of the component in the picture.
    If you get really stuck, Bipolar, Low ESR capacitors will work in just about any appplication provided you can get them to fit on the board and you match the capacitance and voltage and temperature ratings - they're just more expensive and harder to source.
    A.
  • Alastair Macleod
    Extra thought - if you look on the board, are there any clues in the paintwork? If either of the holes the capacitors are mounted into is marked with a plus or a minus, that would be a clue you didn't need a bipolar cap.
    Similarly, there may be a capacitor symbol painted on the board (two parallel bars, each with a wire going to it). If one of the bars is coloured in, while the other is shown in outline only, this also indicates that a bipolar component isn't required.
    NB. If you buy polarised (ie not bipolar) capacitors, make sure you solder them in the right way round.
    A.
I am replacing the powerboard on my samsung flatscreen and trying to avoid risk of electrocution
Good precautions indeed. Just don't touch the underside of the circuit board with bare hands. The capacitor are the round tube shaped things. Hold the board by the edges. They are readily available online or at a place like Radio Shack.
Mar 04, 2018 | Samsung Microwave Ovens
I need mainboard for my BenQ T221W
When it have this kind of error is a problem of the powerboard.
This error means: your monitor enter in protection mode!
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters or CCFL Lamps... control the transistors - MOSFET on the powerboard.
Jun 20, 2014 | BenQ T221W Monitor
Blows fuse fsp201-3f01 15Afuse
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 22, 2014 | Westinghouse Electric TX42F810G 42" LCD...
No power. I will open it to see if they have bad capacitor, but all capacitor is good
See the fuses and the input stage where there is a filter and a varistor. Check the rectifiers and the power supply. This is a switching power supply. You might want to secure a schematic before you do the troubleshooting.
Mar 16, 2014 | Chi Mei Corporation CMV-633A LCD Monitor
Lcd tv screen when on goes off after 2seconds
Feb 27, 2014 | Relisys RLT1720 17" LCD Monitor
Inverter black caps
Jan 31, 2014 | BenQ FP91G+ (Black)
White color cloudy screen
Aug 25, 2013 | BenQ Computers & Internet
Black Screen, Power light on
Aug 03, 2012 | BenQ FP767-v2 - 17" LCD Monitor
It doesn't turn on my monitor, lights always blinking.
if this is an amber light, It reflects an Hardware malfunctionality.
do a test if it works it is fine else you need some one who can repair your Laptop.
remove cables and sakeep pressing power button for 3 mins.
insert all the cables back. it may work.
Sep 29, 2010 | ViewSonic VA1912w 19" LCD Monitor
Philips lcd tv doesn't turn on no power at all
I replaced 3 capacitors on the powerboard. They were listed as 16v/1000uf and all 3 had popped(the tops raise up). I learned on another forum that replacing these capacitors to 24v/1000uf would fix the problem and...it did. My LCD works fine now.
Supposedly all the powerboards were sub-contracted out to another company. To verify exactly which capacitors to change I looked up pics of the powereboard on E-Bay and was not surprised which ones had been changed. It cost me $5 to fix my LCD TV.
Sep 12, 2008 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
2,128 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
