Question about Microsoft Windows Vista Ultimate Edition
Hw to install windows vista transformation i hv setup but it is giving me some error like unexception error handler win32
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Dear madam
there is a problem with your operating system cd.
please try by new cd.
please rate my solution
regards
murali
Posted on Dec 31, 2008
Am trying to install vista on my windows xp-sp2 but it gives "spinstall is not a valid win32 application......how to install then???
Are you doing a Dual-Boot? With a Separate Partition on the Primary HDD? I'm a bit confused? Are you doing a install on the Primary HDD and installing over the Win XP? Did you format the HDD? Or on a second HDD?
Mar 20, 2013 | Microsoft Windows Vista Ultimate Edition
Win32 application is not valid
Hi bconejarez,
Regarding that Error you just mentioned it is either the program you are installing is not compatible with windows or the programs can be just damaged but if it something brand new then most likely it is not a windows Program or application.
You can also tr and check for issue like your Anti Virus program try disabling your Anti Virus for a while then try re installing the program again see if the error will occur again, if the error still occurs then it is the program you are installing that is the issue.
If you think that it is not the issue then you can try to back up all your personal stuff then re install windows and try installing the program on the newly installed windows see if the error will occur if it does then you will have to get a new copy of that program which is Windows Compatible, or possibly that is not damaged.
What Application/program is this that is giving you this Error not a valid win32 application?
and what windows do you run on your Machine is it XP. Vista or windows 7 also is it 32bit or 64bit?.
Thanks I hpoe this can clear thing out on you concern.
Have a nice day, Thank you for choosing Fixya.
mvincentc
Jul 15, 2011 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Problem installing Caesar 3 on Windows Vista
Hi!,
I'm using a vista premium SP 1.. So I did got the above errors.
What i did was, explore the disc-->right click setup.exe and click properties--> compatibility tab--> select run for win xp 2 and under admin.
Then when I installed I choosed a MINIMAL install option. If you the the above step yet choose full the error comes up.
Should work :))
Its annoying to insert disc everytime when you wanna play because of the minimal installation option but i figured to 'burn' and .iso image to my hard disk and use a cd/dvd image mounting tool. This part is purely optional tho:P
Jan 30, 2010 | Sierra Online, Inc. Caesar 3 for Windows
I have windows vista and cannot download itunes, it says something about win32 error
Well to support this I would need a little more about the error. If you can give me the complete error message.
Or else you can try this link and it will definately help you...
http://support.apple.com/kb/TS1717
Thanks
Deepak
Oct 28, 2009 | Microsoft Windows Vista Home Premium with...
My computer is infected with win32:vitro, win32:trojan gen{other} and HTML:IFRAME-HW[Trj].. please tell me what to do, i have tried installing fresh installtion of window vista. but the viruses and trojan...
Avaste is good but I suggest using another
program for your problem. Actually 2.
SUPERANTISPYWARE (free)
http://www.superantispyware.com/download.html
PANDA ACTIVE SCAN ONLINE (free)
http://www.pandasecurity.com/homeusers/solutions/activescan/
Also, when infected, I suggest running in safe
mode. Also delete (disable) Restore Point as
the infection could be in a backup set. Be sure
to enable it when done.
Hope this helps.
Jul 10, 2009 | Computers & Internet
D:\setup.exe is not a valid win32 application
I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
Dec 04, 2008 | Microsoft Windows XP Professional With...
How to format vista home?
If you run the recovery CD you do have, when it reinstalls the operating system, it should also reformat the hard drive first, and give you a completely clean install.
are you trying to install a different version of windows? are you running the recovery software from the HP CD, or from the local hard drive?
also, when you run the recovery software, does it give you an option for what kind of recovery to run? Be certain to select the most thorough option listed.
Mar 29, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
