Question about ASUS A8V-MX Motherboard
When i switch on my computer the power led just blinks and nothing happens
  • Matthew Bromley
    Matthew Bromley May 11, 2010
    Hey memanu, Matthew here. hmm interesting problem. It could be a number of things. Would you post some more info on the make of the pc and when you got it please. Any other info you think relevant also so. Many thanks. Matthew.
First off, remove all pc cards, & switch out the HD with a known good one. Is the fan on the cpu rotating? If not after doing the above, I can't help you Fritz
Posted on Feb 08, 2010
    Champion:
  • 254 Answers
Try removing the cmos battery for about an hour , make sure the power is out of the computer before removing
Posted on Dec 31, 2008
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Power supply LED (Green) turned to red and blinking and nothing works
Power Supply is bad. Plain and Simple. Replace it. Regards, joecoolvette
Aug 31, 2012 | MSI Hp Compaq Evo Ms-6541 Rev 1.0...
Lenovo N440 doesnot turn on
hi, check for low battery try to full charge first. then check the power adapter if their is an output going to the laptop.
Mar 29, 2012 | Computers & Internet
On a 80% Rheem upflow furnace... The AC works fine but when switched to heat nothing happens. "OK" LED is on solid, second LED is blinking 3 times, "FLAME" LED is not on at all. What can be the problem?
Hello ANGUS,I think 3 blinks is open pressure switch,try taking the door off the furnace.The upper left hand side is a round black box with a hose attached to it .Gently tap the switch(box) and turn off power for 2 seconds andback on,then call for heat.the blower door has a sticker inside that tells you just what the blinks mean.
Aug 10, 2010 | Heating & Cooling
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Red LED standby button is blinking red. Amplifier is switched on and after some 5 secs switches off on its own with red LED still blinking. If OFF on remote is pressed red LED stops blinking, however...
There is a problem win the power supply. I would look for swollen/leaking caps and also any cracked , broken devices in that general area and replace them
Sep 04, 2017 | Denon AVR-5800 Receiver
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
ASUS A8V-MX Motherboard Logo
95 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
