Question about Dell Latitude D600 Notebook
DELL D600- UNABLE TO DETECT HARD DISK TO BOOT SYSTEM
MY DELL D600 WON'T BOOT BECAUSE IT CANT DETECT THE HARD DRIVE BECAUSE DURING A DISK CHECK IT HAD MOVED THE HARD DISK FILES INTO QUARINTINE BUT BEFORE IT HAD FINISHED RESTORING THEM THE DISK CHECK ABORTED DUE TO LACK OF DISK SPACE, NOW IT WON'T BOOT. PLEASE, PLEASE HAS ANYBODY GOT A SOLUTION???
  • 122 Answers
You might have to reformat the drive sounds like you got a virus in your boot sector on the hard drive.
I hope you backed up everything you needed. when ya get it running again get an external drive and make regular backups of your stuff.Where did it move the files to ? you should have a backup of your system on your harddrive that came with the machine when you bought it ,try to reformat with this sector of the hard drive its called d: backup
Posted on Dec 31, 2008
Dell inspiron 1545 laptop wont boot. Error unable to locate hard disk drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 21, 2012 | Dell Inspiron 15 1545 Notebook
I cannot format my dell computer
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
May 15, 2011 | Dell (04U621) for Latitude D600, Inspiron...
Hi, my Dell latitude d600 won't start I mean it comes on and looks like it's starting up but then it says no bootable devices found.... I've checked the battery and made sure I still had the hard drive but...
You may want to check for good hard drive connection cable to see if this solve you problem.
Another essay you can do is to enter the bios (normally you should press F2 or F10 or DEL key, follow what appears on the screen during the boot) and see if it can detect the hard drive. If the bios cannot detect it most likely you are facing a hardware problem, maybe a mainboard problem.
Mar 22, 2011 | Dell Computers & Internet
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
H.D failure
Its definitely the Hard drive that might have crashed. You can try booting the system by using a windows CD and see if it boots. Secondly you can try using a different hard drive from some other laptop, if you know someone using this one. Or you have to purchase one. If you think of replacing it with a new one, I can assist you to replace it. Dont take it to a service center, they would charge you a good amount.
Feb 06, 2009 | Dell Latitude D600 Notebook
Bios and boot problem....
before installing ,, put the cd-rom in the bois number 1. click it then press the minus sign, "-" and put the cd,, then restart it, the installation begin
Jan 02, 2009 | Dell Latitude D600 Notebook
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
687 people viewed this question
Alun Cox
