Question about Hotpoint Aquarius WF220 Front Load Washer
Wff220 will not start when door closed - lights up briefly
Is there a reset button ? if i close the door really firmly all of the red lights come on - then go off again - machine will not switch on
  • Hotpoint Master
  • 3,463 Answers
If you press and hold the door and the lights come on, then I syspect that the door catch or spring may be broken.
If it has a start/pause, try that.
Hope this helps.
Posted on Dec 31, 2008
Where and what does the reset switch for the 1996Volvo 850 lookslike
Volvo 850 (1993-1995) Service Light Reset
Under the hood there are 2 diagnostic units (labeled A and B on the cover) next to the washer reservoir.
1. Turn on the ignition and open diagnostic unit A.
2. Locate the flylead (the test wire that is in the plastic holder).
3. Insert the flylead into socket 7.
4. Press the large round test button on the diagnostic unit 4 times, briefly but firmly.
5. When the LED flashes and then stays lit, it will accept the reset code.
6. The reset code for the service light is 1-5-1.
7. Press the large round test button firmly one time and then release it. The LED should be lit.
8. Press the button firmly 5 times and then release it. The LED should be lit.
9. Press the button firmly one more time and then release it. The LED will flash several times.
10. Turn off the ignition switch and replace the flylead in its holder and close the cover.
The Service Light has now been reset.
May 13, 2015 | 1996 Volvo 850
Red light error
How to reset samsung 1640
Oct 26, 2014 | Samsung ML 1610 Laser Printer
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
We have a Whirlpool WFS1071BW, and it has just stopped working for no reason. When you start the cycle (any cycle), it starts and then after 5 seconds or so, stops, the "Start" button light...
The problem is the door switch likely broken or not being activated. Make sure the door is closed firmly and nothing is caught in the door that might prevent the door from closing tightly. Replace the door lock/switch assembly if the door is closed firmly. You should hear the door lock/switch clicks when Start is pressed.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Mar 06, 2011 | Washing Machines
Bllinking "clean" and cant start a new load? Need to reset? How to reset?
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
-high temp wash
-heated dry
-high temp wash
-heated dry
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
My clean light is flashing....call service to check heater?
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
