Question about Dell Latitude D600 Notebook
My dell laptop doesnt turn on
It just started being hard to turn on and then it just stopped being turning on and i dont knwo whta is the problem.
Sometimes it starts and sometimes it doesnt
  • carpentoya Jan 10, 2009
    i press the off/on button and the light where the cap lock is flash and the charge light flashes.l it makes a booting up sound and then it turns off. the screen dosen't even turn on
  • 49 Answers
Remove the bezel avove the keyboard with a small flat head screwdriver. Press the power button with your finger and see if it powers up. If it does, just replace the bezel. If not, then you could have a bad system board.
Does the battery show a charge when you press the button located on it? Does the power adapter show a green light when it's plugged into an A/C outlet?
Posted on Dec 31, 2008
  • Greg Lumpkin
    Greg Lumpkin Jan 14, 2009
    carpentoya,
    It means that the memory has encountered an error. Try:
    1. Reseating the memory.
    2. Replacing the memory.
    3. Replacing the system board.
Well my problem is that some times my computer crashes and it just turned screen black but i checked the disk and it doesnt has a problem then i found out that theres a controller AQFF4KEX IDE...
If you disable the IDE controller, the hard drive connected to it will not function.
You should find your motherboard manufacturer and download its drivers and install them.
If you purchased your PC from Dell, you should be able to find this software from support.dell.com.
I hope you find this information helpful.
Mar 02, 2011 | Computers & Internet
When I was working on the internet, the system suddenly announced some fundamental failure and started to turn down, and surprisingly he did it and turned off completely. When I turn up my Laptop, the...
Reinstall the operating system from the setup disk. Unfortunately, you may need to reformat it and loose your data. It's probably a corrupted hard drive.
Feb 11, 2011 | Dell Inspiron 1525 Notebook
Blue screen of death appears every time i try to turn the computer on and then it turns off, I made so it doesnt immedietly turn off and now i dont know what to do the tech info is : stop: 0x00000024 ...
you need to remove the hard drive and have it scanned with malware software and antivirus software. the laptop or computer you use for the scanning must be clean of virus it's self.
Mar 09, 2010 | Toshiba Qosmio F25-AV205 Notebook
My dell d505 latitude laptop has the dreaded
Sounds like your battery is dead. They go bad in laptops and need to be replaced in a couple years.
1) Unplug your battery and power laptop on with just AC adaptor. If laptop runs normal then you need to replace battery.
2) If it doesnt turn on at all then your motherboard may have a problem. The power supply is integrated on MB on most/all laptops.
2) if you need a motherboard replacement, try http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&cs=19&l=en&s=dhs
Nov 25, 2009 | Dell Latitude D505 Notebook
Dell D600 when powering, leds blinking
Its a motherboard problem. check all the flashing codes here.
CLICK HERE
it will give you all the information about the codes.
Sep 26, 2009 | Dell Latitude D600 Notebook
My dell laptop turns on but doesnt start up...
Thiers a huge possibility its a software problem or maybe the backing light in the screen, if a software problem the system needs reboting,No problem
Sep 17, 2009 | Dell Latitude D505 Notebook
DELL 1501 inspiron wont start up right
ok well u may have a worm in your system !
the easyest way to solve your problems is to do a full re-install of the operating system
do you have a dell restore cd/dvd ?
put it in the optical drive and turn power on then press F12 key until you get a boot up menu select cd /dvd drive and press enter
this will start the install of the operating system
Hapy trails.
Nov 17, 2008 | Dell Inspiron® 1501 (N11157) PC Notebook
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
My inspiron had hard disk problem...
Windows setup: Compressed volume or disk-cache utility error. fdisk <press enter>; In fdisk choose the option to display partition information (option 4). Determine the type of system currently setup on the hard disk .
Good Luck, Please dont for get to Vote. Thank You.
Dec 19, 2007 | Dell Inspiron E1505 Notebook
Dell Latitude D600 Notebook Logo
71 people viewed this question
Alun Cox
