Question about Honeywell Programmable Thermostat Heater
Changed timeclock and system no longer works correctly!
I stupidly changed a Danfoss 4033 timeclock to a Grasslin Q2 , before getting any connection details for the original Danfoss. I have tried to find schematic drawings to suit the various valves and switches but so far I,ve failed . I,ve got two motorised valves one in the HW and one in the CH pipework both spring return and both only two wire i.e Live and Neutral . A cylinder stat with N/O and N/C contacts and a Room stat with N/O and N/C contacts along with the previously mentioned time clock with HW on HW off HTGon HTG off connections . It,s all got a bit frustrating . I know the boiler requires a switched supply as well as a permanant live and the frost stat is connected across these two cables .But I.m stuggling to get it to work without the Aux switches usually within the motorised valves. Can any one help ?
5 Suggested Answers
  • 70 Answers
SOURCE: Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Posted on Jan 16, 2009
  • 3089 Answers
SOURCE: Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
Posted on Feb 18, 2010
SOURCE: clock correct but next cycle starts too soon
Try reading my Tip on programming thermostats. I think it will solve your problem. Roger
Posted on Feb 13, 2014
  • 3368 Answers
SOURCE: Have a ct87k. Got power at wall. Plug t-stat nothing.switches are both off for gas.
Those normally do not fail, they have a mercury switch in them. However there is a cravat they have to be mounted level and up side up. If that is the way it is mounted then just replace it.
Posted on Dec 19, 2014
Grasslin Uni 145. Why isn't it working?
In an electromechanical timer such as the one illustrated, you must rotate the dial clockwise (as shown by the arrows on the dial) to reset the time. The "easier" alternative of rotating the dial backwards will destroy it.
Apr 15, 2016 | Hardware & Accessories
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
I have a 2010 rca tv model 4033 have sound but no picture just happened yesterday
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 01, 2014 | Televison & Video
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
http://www.grasslin-controls.co.uk/ecosave.html
Aug 25, 2012 | Hardware & Accessories
Reset David-Link Model W-988PB timeclock
HI
RUN TIMECLOCK PROGRAM
GO TO TERMINAL CONFIGURATION
AND RESET ADMIN PREVELGE
Feb 17, 2012 | David -Link W-988 Biometric Time and...
Samsung Q2 not recognized by Windows Media Player 9. Reading it as a "camera". How to get it to recognize/synch?
disconnect from ur pc and then go to settings > system > PC Connection > make sure MSC is selected.
Jan 25, 2010 | Samsung Q2 Digital Media Player
Joe is writing, I have a Sundstand hydraulic pump mounte on a concrete Rexmixer machine. The pump can only sustain for 5 minutes working time and all sudden it won't be able to deliver enough power to the...
It sounds like your hydrostat pump and motor are failing (leaking too much). Seals will not fix this problem. Send me your model numbers for verification and further info.
Oct 19, 2009 | Danfoss Sundstrand-sauer-danfoss...
Q2 is not recognized by PC. won't transfer any MP3s from PC
no need for drivers, on your Q2 go to Setting > System > PC Connection > MSC
Sep 04, 2009 | Samsung Q2 Digital Media Player
SECUTITY TO STOP OTHER PEOPLE USING MY WIRLESS INTERNET
I connected to my Belkin G Plus MIMO router using IP address 192.168.2.1 to enable security to prevent others connecting to my system. I enabled password just to start with. I also changed Time to GMT time and I changed someting about Server to European (I forget what exactly it was). The result was when I confirmed these changes my router will no longer respond to this IP address and no longer works for me. How can I get connected again to change timngs !
Sep 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
