Question about Samsung CLX 3160fn All-In-One Printer
Deve home sensor erro - Samsung CLX 3160fn All-In-One Printer
  • Anonymous Jan 13, 2009
    my printer gives me the error message: DEVE Home Sensor Error, when i try to print. Does anyone know what this means and how to solve it?
  • 526 Answers
This will usually solve the problem.
Open the front door, take out the Drum / Toner cartridge assembly. Blow with air on the left side and right side to blow out the toner. do not have the air to close to the unit so that liquid sprays out, and as much as possible, avoid the drum. Then rotate all the black gears, 2 full rotations as possible. The drum gear will be the hardest.
This should solve the problem.
Posted on Mar 11, 2010
  • 23 Answers
Open complete body of the machine. right hand side you will find developer drive assambly attached with gear assambly.this assambly contains one solonoid and one multi step clutch unit.
you will find one spring on solonoid unit.remove that spring and cut it in middle.take one part of the spring and bend one ring of spring from cut side to make proper shape. fix it back to solonoide. this is just for increase tension on stopper liver.
it will solve your problem for DEVE HOME SENSOR ERROR.
GOOOOOD LUCK
Posted on Mar 27, 2010
SOURCE: deve home sensor error
the transfer belt is worn or covered in toner or has a label stuck on it or the sensor is dirty.
Posted on Jan 06, 2009
ghassun
  • 499 Answers
SOURCE: Deve home sensor error
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
Posted on Jun 09, 2009
  • 68 Answers
SOURCE: DEVE HOME SENSOR ERROR
replace the toner cartridge
Posted on Oct 05, 2009
  • 12 Answers
SOURCE: deve home sensor error on samsung clx-3160
This can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Below steps are for the CLP-300 which has the same Imager/Developer. It's just a bit more involved taking off the top in the CLX-3160.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Posted on Jul 10, 2010
  • 12 Answers
SOURCE: samsung clx-3160fn deve home sensor error
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
HOME SENSOR EROR
Deve Home Sensor Error
There is a problem in the fuser unit.
Unplug the power cord and plug it back in. If the problem persists, Replace to the Main board.
Aug 30, 2011 | Samsung CLX 3160fn All-In-One Printer
Get the error message at a samsung 2160 printer: error deve home-sensor. What can i do..........
Dear
Deve Home Sensor Error indicates a problem in the fusser unit.
Unplug the power cord ,check the fusser unit and plug it back in.
Main board.
Jan 16, 2011 | Samsung CLX-2160N All-In-One Printer
Deve home sensor error on samsung clx 3175
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
Sep 24, 2010 | Samsung CLX 3160fn All-In-One Printer
I receive an error message DEVE Home Sensor error
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Problem for Samsung CLX-3160FN All-In-One Printer Deve home sensor erro
Please check the sensor of front door or back door, one of these are not working, chec softly by rolling your finger on it, and let me know if this works or not i3game@cooltoad.com
Mar 24, 2010 | Samsung CLX 3160fn All-In-One Printer
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
Jun 19, 2009 | Samsung CLX 3160fn All-In-One Printer
Jun 09, 2009 | Samsung CLX 3160fn All-In-One Printer
Dec 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Dec 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
542 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
