Question about Nokia 6102 Cellular Phone
How to send files to pc from my 6102 cingular phone
I have my IrDA infrared device attached to my pc but i dont know how to send pictures to my pc from my cingular phone. i tried but it doesn't work at all. i don't know if it doesn't work or if i just don't know how. the devices says it is working on the settings on my pc.
thank you...
  • 495 Answers
Better try with a USB cable, connect your handset to the PC through USB cable and then try to send pics to your handset. Dont forget to install your driver software for the handset to connect to your PC.
Posted on Dec 31, 2008
How to use infrared port in sony ericssion k220i . what is main use of infrared port. what can i do using this facility?
The infrared port is by the left side of the phone, it is along the line that splits the front and the back of the phone. It is mostly covered by a thick red glass or plastic.
Infrared is a device on a phone that allows you to send and receive file using the infrared radiation wireless wave. It works like a bluetooth device, just that it must be placed close to the infrared port of the phone that is sending or receiving files from. You cannot send or receive files that does not have infrared using your own infrared.
Infrared can be used to send and receive files (data, song, pictures, videos etc).
To use the infrared of the sony ericsson K220i, you have to go to your phone 'menu', go to the 'settings', select the 'connectivity', then you select the 'infrared', turn it 'on', when you are to receive a file, you place your phone close to the sending devices infrared port. Also when receiving a file, you do the same.
When you want to send a file through infrared, you go to the file you want to send, you select the option, select send from the option, a pop up blog will come up asking you how you want to send the file, you select via infrared and your infrared will come on, the device you are sending it to would have its infrared turned on as well. The infrared ports must be placed close to themselves before the files can be sent.
Take care
Jun 25, 2010 | Sony Ericsson Cell Phones
How to install games to motorola c650
hi there,
You can download ganes to you phone through different methods like: Over-the-Air (OTA), Infrared (IR), Bluetooth and Cable
1. For uploading through OTA: make sure your wap is well configured and working (each operator has different settings). Enter the .jad url of the game (URL of jad can be found below), then the phone will automatically download the .jad file. After the .jad file is downloaded you will be prompted to confirm the downloading of the .jar file. If you press yes then you can download the file and install the game. Volia! In general you should make sure that the .jar file will fit on your phone. Some devices like Nokia Series 40 (MIDP1) limit the .jar size to 64k, others will limit it to under 100k. Also most devices have a low limitation on the size of all games (midlets) installed, so you should always check the available memory and in some cases remove any old unused games. We have taken the limitation of each device into consideration and there's nothing to worry about here.
2. For uploading through Infrared: First you should get an IRDA peripheral and connect it to your PC. It's usually a USB device. Connect it and install the software.
Now there are two cases:
a. either your phone supports IRDA directly and in such case it's sufficient to upload the .jar file to your phone by right clicking on the file and use 'Send to' menu. Note that you should configure IRDA properly to connect to the phone. We are using the following configuration for SigmaTel USB-IRDA: "Infrared Transiver Type": SigmaTel 4000, "Min. Turn-Around Time": 1.0ms, "Speed Enable": 115200.
b. or your phone doesn't support IRDA directly but has IR. In such case you should use your manufactorer software like Nokia PC Suite.
3. For uploading through Bluetooth: Usually this is faster and easier than Infrared. Install your Bluetooth usb device. Right click on the .jar file and select the menu 'bluetooth device' inside 'send to'. You can also pair your device with your computer to make things faster. Once the .jar file is on your phone then you can install it
4. For uploading through cable: some phones don't have neither Infrared nor bluetooth support. You can use the manufactorer cable and connect it your PC (either USB cable or com cable). In such case you should also use a dedicated software for uploading files to your device
Please use the below mentioned link to find games.
http://www.zgroup-mobile.com/demos/Motorola_C650/index.html
thanks,
S.
Nov 20, 2009 | Motorola Mobility C650
Where is irda on hp pavilion 6700??
This model does not have irda. It has an infrared sensor on the front edge below the touchpad, but that's just for a remote control device. Full specs and a service manual are available on HP's UK site, and no reference is made to any model of this series including irda.
May 12, 2009 | Dell Inspiron 1525 Notebook
This model series does not include irda. Full specs and a service manual are available on HP's UK site, and no reference is made to any model offering irda. It only has an infrared sensor for a remote control device.
How to transfer my images from nokia2600 phone to pc
U CAN USE DATA CABLE AND U CAN TRANSFRE THE FILES ALL AND RATE ME PLEASE
May 05, 2009 | Nokia Handsfree For 6020, 6101, 6102...
Laptop s infrared device, serial cable using IrDA Protocol problem
Sound has nothing to do with infrared devices.
The yellow exclamation mark that you see under the device manager is due to drivers of the infrared device not found or is not installed properly.
There might also be a possibility that the device is not getting recognized by the computer due to corrupted drivers so the drivers of the particular needs to be installed again with the CD.
Jun 04, 2008 | Gateway Solo 5300 Notebook
Infrared wont pickup my mobile phone nokia
Click HERE to go to HP to download your wireless drivers. Select your laptop model, then select downloads and drivers and choose your OS to get the drivers.
May 31, 2008 | Compaq Presario 700 470024-192 Notebook
Transfer images from mobile to computer
i have Nokia 6630..i want to tranfer images from my mobile to pc through USB but i dont know how to connect it & i dont know how to use it..can you help me with this problems?
May 29, 2007 | Nokia Handsfree For 6020, 6101, 6102...
Pairing nokia 6230 with ipaq
No Need to pair IRDA with Ipaq PPC,s most models of Ipaq PPC have Infrared always active try to send a picture to your Ipaq directly from the gallery of your Nokia 6230 via IRDA its should work. U Can not pair Nokia Mobile phones to PPC due to nokia,s Software. But you can pair with a Desktop pc with a IRDA dongle
Sep 19, 2005 | Nokia 6230
Nokia 6102 Cellular Phone Logo
100 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
