Question about Dell Latitude CPI Notebook
Coneection of latitude cpi r400gt internal keyboard connection
Latitude cpi r400gt internal keyboard has two ribon. one is wide and one is thin. i found the port for the wide but not the thin. So where will i connect the thin ribon.
I hate neighbors! I had given my laptop to the boy livin next door and he returned it with the shift key missing. I will have to buy a new keyboard now 
Hi james,
sorry to hear that your kindness to another has been let down .
to replace the keys or the whole keyboard is not too big a job .
try searching on ebay for a replace keyboard ( in the uk around 20 pounds ) or buy a used one and change the key top
this is a link below to ebay as an example
http://cgi.ebay.co.uk/Dell-Latitude-CP-CPi-Series-Laptop-Keyboard-0000309R-/380158661597?cmd=ViewItem&pt=UK_Computing_ComputerComponents_KeyboardsMice&hash=item588338d3dd
Jul 19, 2010 | Dell Latitude CPi A Laptop Keyboard Unit (...
Need to delete bios password on a dell latitude cpi r400gt
I have just done this. One needs to dismantle the laptop first. Solder a push button switch with extended wires across pins 4&5 of the serial eeprom 24c02. Then reconnect the screen, keyboard & a/c power pack. with a tooth pick press power on switch whilst holding push button on. When the factory mode screen comes on release the push button. Next go to bios setup F2 and ALT-p to the password page. Now enter your new password this will overwrite the old pass word. My approach is slightly different to this following method as it is les likely to brick the laptop.
http://www.archive.org/web/2003110302606
Jul 02, 2010 | Dell Latitude CPI Notebook
Left & right arrow keys not working.
Try to connect an external keyboard, see if that one works. If it does, then the problem is most likely a loose ribbon cable from the internal keyboard to the motherboard (especially if you recently installed a new one) - also, while you are examining the cable, look for any tears, cuts, or kinks in the cable. Good luck!
May 10, 2009 | Dell Latitude CPI-D Notebook
Certain keys on Dell Latitude C610 keyboard not working...
I use to have a Dell Latitude CPI and the same thing happened to me. I had to replace the keyboard. Which you can buy at this link:
http://www.priorityelectronics.com/product/Dell/Latitude/C610/3C048/
I have no connections with the company link I provided. Shop and buy at your own risk.
Hope this helps and don't forget to rate.
Feb 28, 2009 | Dell 0Y3740 Keyboard
How to Repair Dell D520 Laptop keyboard??
If you keyboard isn't working and this is the correct one, I would buy it and replace it. I have done this before on a Dell Latitude CPI. Easy to do. Good luck.
Feb 24, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
CD drive
The CD Drive is in the front of the unit as it faces you, just to the right of center, there is a small button, to eject the CD tray.
Hope this helps :)
Jan 22, 2009 | Dell Latitude CP (0001849d-38380-968-p06e)...
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Latitude CPI A-Series
log on to www.dell.com and place an online order for a new DELL system
Apr 24, 2008 | Dell Latitude CPI Notebook
Dell cpx
check your keyboard connector & key board.check the control key, properly it could be happen if it get connected always.
Jan 28, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude CPI Notebook Logo
138 people viewed this question
Alun Cox
