Question about Dual Electronics CECT P168 Cellular Phone
Computer does not reconize i9
I put in mirco chip and it tells me no music on it and when i go into audio player it reads usb function not allowed. is there a cd or some type of hardware I need?
    Novelist:
  • 151 Answers
I) when u connect ur mobile to the computer and select the option data storage mode, then u will not be able to access memory, u will get message usb function not allowed(here audio, video, player, camera , mostly some functions wont work when connect ur cell to computer)
Thanking you
M. Sridhar
Posted on Jan 03, 2009
Why cant i put music on my lg env3 from my mirco sd card?
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storagethis will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Music, drag your mp3's to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive.
jh3:16
Jan 20, 2010 | LG enV3 VX9200 Cell Phone
Sansa view was nt reconized
hi! install first a software of your cp.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
How get music from memory card to the audio player in a I9 phone
Alternatively, use your file manager and open the directory where you have stored the music files. Click on any song and that should open the music player. If that does not happen then check the music format. It shud be the same as the phones supported one. For example mp3 or aac or whatever your phone supports.
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
My cect i9 phone won't read the sd card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jun 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Trying to load music on the i9 3g cect phone
make sure you have your phone set up to look at the memory stick and not the phones internal memory. you have to select the memory card as the prefered stoage, the phoen is set up to default to the phones internal memory unless you tell it differently.
Apr 03, 2009 | Dual Electronics CECT P168 Cellular Phone
My computer does not reconize any files on My player
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Jan 10, 2009 | GPX ML648B MP3 Player
I9 downloads
For music i use and LOVE Blubster..go to www.blubster.com select the free download--have never had a problem and always find all the songs i want..and its FREE..download the music to your computer then plug the USB cord to the phone to the computer and it should pop up the files..save them to your music file in device F(your memory card)--device G is the phones memory and if you put them there it will tell you the file is to large..
For videos and music videos..my favorite and FREE site is http://www.mv3gp.com/ I love that site..
3gp is the format all cell phones use for video..so if you need more google free 3gp videos and more sites will pop up..But these are just the TWO i use personally and LOVE.. for the videos same as music drag the file to the F device in your video files..Voila..
Then you can find them in your phone under your documents icon and under memory card..or in your multimedia icon and audio or video player
Nov 14, 2008 | Dual Electronics CECT P168 Cellular Phone
I cant download music
Music Service or from CD
Oct 06, 2007 | Dell DJ Ditty MP3 Player
Dual Electronics CECT P168 Cellular Phone Logo
128 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
