Question about Logitech Cordless Internet Handset for Skype IP Phone
"access to skype is rejected - try again"
I keep getting the captioned dialogue box in spite of having installed the software correctly. the handset is in "offline mode" and does not switch on to "away".
i can talk on skype quite well on manually attached speakers and microphone.
will appreciate your solution to this problem. thanx.
  • kirsirytkone Jan 04, 2009
    I updated my skype, and before my logitech wireless skype phone had worked perfectly, but no it claims: unable to connect to skype, and the phone just reads unavailable. I have checked firewalls, and tested the equipment, even tried to reinstall the phone, but nothing works. Anyone?
sandrew
  • 2961 Answers
SOURCE: Logitech Quickcam Express - picture but no sound
Within the software that is used with the cam, the sound sometimes needs to be enabled in the options settings, and set up similairly in windows live.
Posted on Jan 27, 2007
SOURCE: QuickCam mic doesn't work
For XP users,try:
>Start
>ControlPanel
>Sounds and Audio Devices
>Audio
>Sound Playback
Click on drop down menu arrow.
If there are two audio devices listed: Deselect current device; select second device.
>OK
Posted on Dec 10, 2007
I read another post that said to go to Logitech itself for up-dates. This I did......downloaded all new drivers, etc. (the disc that comes with the cam must be out of date !). Then when that was done, I went back on Skype and where you do a 'voice test' I was able to this time around to "choose" my webcam - this was not coming up before at all. So in doing that it activated the mic on the webcam and all was OK. We seniors are supposed to be savvy with the forever changing world of electronic devices today! (LOL)
Posted on Feb 12, 2009
SOURCE: Loaded Skype . My friend can't hear me talking.
try and change the audio settings under the tools menu option of skype and goto the general settings. You will find the audio and select for the correct audio device.
Posted on Mar 21, 2009
SOURCE: I have a Logitech Pro 9000. After installation, I
I have version 4.0.0.206 of Skype. Don't know whether this works on versions below that. If in doubt update your version of Skype, the current version is 4.1, click here to download it if needed.
Within Skype, click Tools, Options
Click on Audio Setting, in the General Tab. Now under the microphone section, click on the down arrow and select your other device and then click 'Save'.
If the other device is not present it may need to be re-installed, Nik.
If this helps click YES below.
Posted on Jun 30, 2009
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Since downloading latest version as soon as it opens it automatically starts in the Itunes store mode and a dialogue box appears with the green tracer bar saying accessing Itunes then changes to cancelling...
its a weird issue
you should try unisntall the itunes using and uninstaller software like clean uninstaller, your uninstaller, etc
then reinstall the itunes again
Mar 29, 2011 | Apple iTunes
The handset is unable to receive calls via Skype,nor am I able to make calls via Skype Handset says Disconnected
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
Feb 08, 2010 | Logitech Cordless Internet Handset Phone
Cannot connect Skype to Internet?
There is a version 4.1 Skype. You might need to upgrade by going to skype.com. If you already have the latest upgrade and you are on a LAN you might want to configure your LAN settings to allow access for skype. Otherwise, if you have a direct internet connection and you can get on the internet with your browser, you'll need to configure your connection to allow skype. If you have McAfee or Norton or another firewall you'll have to go to the program permissions to allow Skype. If you are also using Windows Firewall you can follow these steps to allow Skype to pass through your firewall.
Go to START + CONTROL PANEL, THEN RIGHT CLICK ON NETWORK CONNECTIONS. IN THE DIALOGUE BOX CLICK ON PROPERTIES. IN THE NEXT PANEL CLICK ON "ADVANCED". There you can set your Firewall settings to except Skype, Just click on SETTINGS + ADVANCED + EXCEPTIONS. Make sure Skype is checked. This will tell your computerl to allow skype to access the internet without being blocked by your firewall.
I hope this helps, but usually when you install Skype these settings are changed by the setup program. I suspect you have a firewall you will have to set manually. If you use Zone Alarm or some other firewall you will have to search the for help on your firewall support pages.
Oct 01, 2009 | Computers & Internet
Wont print no print dialogue box
Here's a link from HP website that will scan and try to fix the problem automatically. Also insure the driver installed correctly with software.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01072463&lc=en&dlc=en&cc=us&lang=en&rule=15233&product=501857
May 26, 2009 | HP Deskjet D4160 InkJet Photo Printer
VOIP321 - "ACCESS TO SKYPE DENIED"
http://www.support.philips.com/support/html/index_us_en.html TRY HERE.RICHARDM69
Dec 06, 2008 | Philips VOIP3212 IP Wireless Phone
Phone not picking up contacts
Remove the batteries from the handset for at least 1/2 minute and reinstall them bach. This should work The contacts will show up again on tehe handset.
Dec 16, 2007 | Philips VOIP3212 IP Wireless Phone
Logitech internet handset "UNAVAILABLE" error
Mine was working fine at one point. I had been using it the night before without issue. However later on when I went to make a call the next day the handset said Disconnected.
Any Skype functions said "Unavailable". Rebooting the PC, Restarting the Headset Software and Skype didn't fix the issue.
The fix for mine was to go into "Menu" then "System" on the Handset and do a reset. Soon as it was done, the Skype info popped backup on the handset and it was fixed.
For those who haven't changed it, the default PIN on these handsets is 0000 <-- Zero's
Oct 03, 2007 | Logitech Cordless Internet Handset Phone
Logitech Cordless Internet Handset for Skype IP Phone Logo
226 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
