Question about Sanyo AVM-3659S 36" TV
TV Cable connector issues, Evil Dog
The TV itself is good as new, but the problem is the connector between the TV and the cable, where you screw the cable on, Has come out. My dog was being playful and ran behind the TV, snagging on the Cable cord and pulling it, as well as the connecting part, out of the tv. I've since lost the connector and the small wire that was soldered to it, but is the TV still repairable? Or should I just trash it?
I can't seem to connect my cable box to my Olevia "37" tv.
Help!
Posted on Feb 09, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
But is the TV still repairable? yes it just a simple problem call tech he will do it at your home in a short time.
Posted on Sep 25, 2007
HMDI 1 and 3 do not work (why) ?
Since you did not mention HDMI 2, I assume you have that connected to something else, and that is working properly. The following procedure is based on that assumption.
First, turn off everything connected to the set, and the TV itself. Disconnect the HDMI cable from whatever is going to HDMI 2 (leave the TV end alone for now) and connect it to the PS3. If the PS3 shows up on the TV, the problem is most likely a bad cable. To verify, turn off the PS3 and the TV, then move the known good HDMI cable to either HDMI 1 or 3. If the PS3 works on those also, the HDMI cable you had originally connected to the PS3 is defective. I know there are some bad ones out there; there is at least one lot with a right-angle connector on one end and a straight connector on the other that has a very high failure rate.
If the PS3 does not work with a known good cable to HDMI 2, then the PS3 has a problem. Try using a component (RGB) or composite (yellow end) connection to narrow down what the issue is.
If HDMI 1 and 3 do not work with a known good cable or any input source (DVR or cable box), then the HDMI switching circuit inside the TV is defective. Since the set is "new" that would be a warranty issue.
Jan 03, 2015 | Westinghouse 55" Class - LED - 1080p -...
My cable connector pulled out from the tv and now the tv won't stay on the power button will blank three times and go off what can be the problem?
when the cable got pulled it broke a connection on the board , and thatswhy it won't come on
it will need to be resoldered where the cable was pulled
need more help just ask me!
electech
Oct 26, 2008 | RCA Televison & Video
I have Dish Sattelite. The screen on my JVC digital tv says digital strength is low. Do I call Dish? or ?
This sounds like a cable issue. Assuming your Dish receiver is connected to your TV with a HDMI cable (ends are rectangular and the connector is trapezoid in shape), you can first attempt to switch HDMI ports on the back of your TV. If you get the same message, you can try flip the cable end for end -- plug the TV end into the receiver and the receiver end into the TV (I know, sounds silly, but has worked for me). Next is a new (better -- don't get a $5 cable, most good HDMI cables start close to $20 and up depending on length).
Now if you happen to be connecting via a "standard" TV cable (RG 6), first make sure that the cable is screwed on snuggly (no wrench needed, just finger tight). Next is to get a new cable.
May 01, 2014 | JVC AV-20020 20" TV
Horizontal,wavy lines on sony xbr4 46" sony lcd tv
Disassemble rear panel, check all ground wires and connectors.
UNPLUG TELEVISION. While off, reseat every connector you can find on the back of the unit (unplug and plug in one at a time every single jack/cable connector you can see).
PLUG IN TELEVISION. With power on, carefully loosen (one quarter to 3/4 turn should do it) and then tighten every screw which has a cable attached to it (ground screws) and see if that fixes the picture as you are tightening the screws.
BE CAREFUL AND DO NOT TOUCH ANY OTHER PART OF THE TV WITH THE SCREW DRIVER WHILE YOU ARE TOUCHING SCREWS. Could electrocute yourself.
I had a similar issue as well as blotchy screen and this appeared to have resolved the issues.
Feb 26, 2013 | Televison & Video
What type of cable connector should I use for my Panasonic Viera 32" LCD TV? My old tv uses a screw on cable connector. It doesn't fit my new Panasonic Viera 32 LCD.
The incomming broadcasting signal cable connector are been standard,since the late 80 til now,why doesn't fit,is a mystries to me.U have cable or satalite dish services wright?Call their customer service,they'll send out a Tv tech. to check it out for u.
Dec 14, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Connection for cable box to tv monitor
On the back of the cable box there should be 2 coaxial screw on connectors. One should be labelled "In from Cable" and the other should be "Out to TV". Screw the cable comming from the wall into the "In from Cable" connector and get a short piece of cable to go from the "Out to TV" down the the coaxial connector on the TV. Turn on the cable box. Now tune the TV to either Channel 3 or 4 and you should have a picture.
Oct 12, 2009 | Televison & Video
My tv controls itself
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 27, 2009 | Toshiba 32A33 32" TV
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv connector cable plug slips out
you need to replace your wall cable outlet. This can be purchased at any Radio Shack or Home Depot store. You will find two mounting screws , remove them and you will have access to the junction box. If the cable system was installed in the proper manner you will find a double male connector attached to the face plate by a single securing nut. Remove this nut and replace the double male connector. simple job, hope this was a help to you.
good luck----------------tomtaso
Nov 21, 2007 | GE 25GT240 25" TV
Cable connection generating static on screen & noise
Hi, it sounds like ya most probably gonna haveta resolder the Cable Connection Socket internally.. they often fracture, OR perhaps it is the Actual Cable Connection Plug itself?.. maybe you need to remake this input connection? Indeed it sounds as if the Earth Shielding is making bad contact...
Sep 04, 2007 | Toshiba CF36G40 36" TV
Sanyo AVM-3659S 36" TV Logo
75 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
