Question about HP LaserJet 4250n Printer
Laserjet is Printing shadows
Does this mean there is a problem with the fuser, have tried to print on carstock and changed the settings with the dif. papers. Prints shadows on everything
    Genius:
  • 2,120 Answers
Probably. The fusers are real junk on these models.
Expensive, but simple to replace.
Posted on Dec 31, 2008
Printer hp 2055 fuser error 50.3
Re: hp laserjet 4100tn - 50.3 fuser error
A 50.3 error means that the temperature of the fuser got to high.
Just try switching it of for 20 minutes and try again.
If it happens during a large print job, this may help, if the error returns when powering up the machine, the fuser is faulty, but if so, that means it would have to be replaced.
If you are printing narrow media (A5, envelopes) etc. try printing them in small batches,, and allow the printer to cool of in between batches.
Apr 16, 2014 | HP Office Equipment & Supplies
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
My HP Laserjet P2055dn prints out with a shadow of everything printed.
The ghosting is caused by the fuser assembly. The main user roller has a Teflon coating that keep the toner from sticking, when the coating wears off you start getting the ghost printing like you are having. You can get replacement fusers online from many sources, just do a Google search for P2055DN Fuser. They are user replaceable, only requiring a Phillips screwdriver to replace.
I hope this helps, if so please rate my solution.
BuddyMc
May 08, 2011 | Office Equipment & Supplies
The print looks like it's out of register - the printing leaves a shadow around the words - like smudges
this sound sliek there is a fuser issue. you will want to run a cleanign for this unit if the software provides it or try running the prints at different quality.
this could be a drum issue as well but usually when this happens it means the fuser is not achieving the correct tempurature to properly adhear the toner to the paper causing a smear
Feb 12, 2010 | HP LaserJet 5550DN Printer
My hp 2420 is printing a black line-form
Lines are usually caused by the toner cartridge or the fuser. In order to determine the cause you can replace the toner and see if the lines go away. If not then it is in the fuser assembly and you would need to replace the fuser.
Nov 02, 2009 | HP LaserJet 2420 Printer
Printer
Try this: '''Cleaning page'' in the menu, 1,2.3 times. The quality of print out getting better.
This solution is temporary, for a few pages in one day.
If the printer is used with high intensity, there is necessary to change the Fuser Unit for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v)
Oct 02, 2009 | HP Color LaserJet 2600n Printer
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
PRINTING IS SMEARY AND NOISY
If there is a clicking noise as the printer is printing then most likely the fuser film has torn. The fuser film is part of the fuser unit. This item is best replaced by a technician.
Have you found pieces of film like material around the printer paper exit? It is most likely a dark grey color.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
Shadow on printed page
You either have a bad toner cartridge or bad fuser. Measure the distance from and exact on image printered to the exact same spot on the page it appears again. If it's fuser it will be 41.0mm between image and defect. Any other spacing on the front of the page is usually cartridge.
Try replacing the cartridge first and if that doesnt fix the issue it's fuser.
Here's a link for the service manual. Look at page 117 to get a complete list on repetative defects and their causes.
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%201022%20(Q5912A),%201022n%20(Q5913A),%201022nw%20(Q5914A)%20P.pdf
Hope that helps you.
Aug 02, 2008 | HP LaserJet 1020 Printer
HP LaserJet 4250n Printer Logo
353 people viewed this question
Ben Johnson
