Question about HP Office Equipment & Supplies
Scanning its not finishing scanning! it only goes to 7 percent!!!!!!!!!!!!!!!!
  • 495 Answers
Please reinstall your scanner driver.
Posted on Dec 31, 2008
When tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Apr 09, 2014 | Televison & Video
What is 7 % of 89?
6.23 Percent is a term relative to 100 percent so 7 percent is 7 divided by 100. Using a calculator that would be .07 and then multiply 89 by that. so, 89 X 7 / 100 = 6.23
Dec 20, 2013 | Answer Racing Answer Youth Goggles Answer...
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
The percent of 140 from 762.90 = ?
Sorry to say, soweeto54, but that question you've posted does not make much sense. It can be interpreted in three different ways, neither of which can be gleamed with much confidence. Yet I will still offer you three valid answers for your TI-83,
"The percent of 140 from 762.9 =". The troublesome part is the "from". Percents questions should be written in terms of "is" and "of".
TWO INTERPRETATIONS.
RESPONSE 1. The question could be read as "what percent of 762.9 is 140?". To do this on your calculator you simply do 140 divided by 762.9. From there, you simply move the decimal point two digits to the right to convert it into an equivalent percentage. So, that should be [1][4][0] [/] [7][6][2][.][9] [=] on your TI83. This was an example of a "percent of" question.
RESPONSE 2. The question could be read as "what percent of 140 is 762.9?" To have your TI83 calculate this you simply do 762.9 divided by 140. Of course, you will then need to move the decimal over two spots to the right in order to turn it into an equivalent percentage. Yes, it probably is strange to think of a number being more than 100 percent of another but it is a valid statement which occurs in the real world every single day. Nonetheless, for your TI83 you just press [7][6][2][.][9] [/] [1][4][0] [=]. This was another example of a "percent of" question. In fact, this is just the decimal reciprocal of the previous answer.
RESPONSE 3. The question could also be read as "140 from 762.9 will leave me with what percentage?" IE, 762.9 minus 140 will yield a number which is "x" percent of the original. Here, you would just do 762.9 minus 140, then you would take that answer and divide it by 762.9. From there, you'd do the old usual and move the decimal over two spots to the right for a percentage result. So, for your TI83 you'd do [(] [7][6][2][.][9] [-] [1][4][0] [)] [/] [7][6][2][.][9] [=]. Viola. This was an example of a "percent change" question. In fact, this is just the complement to response number one.
Mar 12, 2011 | Texas Instruments TI-83 Plus Calculator
I have installed windows 7 on my PC.I have DG43NB mother board with core2quad processor.I am facing very irritating problems. 1: after some time if i am not on my PC my PC goes in a standby or hibernate...
Have you checked to see if there are any pending software upgrades that have not been done or have started and not finished. A lot of the time that is the problem. Also check to see if your security is scanning and is not finished.
May 03, 2017 | Intel DG43NB Motherboard
My emachine t6524 wouldn't wake up the next day after running a norton scan. i had to reboot my computer and it would no longer let me access the internet. Now when I check the drive's properties, my...
I would best guess it is a bad hard drive that is an older computer and running a deep scan can finish off a dying hard drive. this is 85 percent the cause of your problem ata best guess. you need to have the internal hard drive tested.
good luck
Jan 21, 2018 | E-Machines T6524 PC Desktop
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
Scanner Canon 5010c
This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
System update will not finish
On mine it gets to 64% and then says there is an error (8002F1F9) and when i turn it off & on again it goes straight back to the update and keeps failing at 64%.
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
