Question about Compaq Presario 700 470024-192 Notebook
How to create new registry
Hi i am Pankaj
  • 716 Answers
A New Registry Would Require Erasing All The Data From Your Computer And Starting Over As The Registry Is Pretty Much The Operating System.
Posted on Jan 06, 2009
Tip
How to make back up of your software settings
<p>Software settings on your computer are stored in the Windows registry. To create a backup of these preferences is made a system recovery. A restore point takes a snapshot of your registry settings and stores them on your hard drive. These restore points when using a plant damaged registry settings that result in errors pop up every time the computer. Windows provides an interface to quickly create a new restore point. <br /> <p><br /> <p>1. Click the Windows Start button. Click "Control Panel" to a new window. Click System and Maintenance link. "Click" System "to the system settings. <br /> <p><br /> <p>2. Click "System Protection", for the utility, create a restore point. If you are not logged in as administrator, a pop-up asking for the password. Enter your password and click OK. <br /> <p><br /> <p>3. Click "System Protection" tab. In this window, click Create a new window. Enter a name and description for your restore point, so you can see the backup. Click Create to create the backup software. <br />
on Jun 22, 2011 | Computers & Internet
Tip
Disable Notification Balloons in XP If you are annoyed with Windows popping up a...
If you are annoyed with Windows popping up a balloon notification telling you things you already know every time you turn on your machine, here is a quick tip on completely disabling them. (Note this requires a registry modification so be sure to back up your registry before making any changes.)
You should note that this will disable all balloon notifications, so proceed with caution.
Click on Start \ Run and type in regedit
Now we will navigate to this path in your registry.
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced
On the right pane right click on an open area and choose New \ DWORD Value
You will see New Value #1. Change this to EnableBalloonTips.
Next double click the new registry entry you created. In the Value Data field set it to 0 (zero). Make sure Hexadecimal is selected under Base. Click OK.
Finally restart your system and enjoy the clean boot up with no balloons popping up at you.
To remove this registry hack, just delete the registry key that you created.
on May 24, 2010 | Computers & Internet
Unable to create new users
This needs to be done with elevated rights (administrator). Open start menu, go to accessories, right click on command prompt, run as administrator
Jun 08, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
I can't get powerpoint 2007 to work.
Solution given by pankaj is very effective but in any case this method didn't work for you then use stellar phoenix powerpoint repair software to fix your problem.
Sep 09, 2009 | Microsoft PowerPoint 2007 for PC
Adobe illustrator
Hi Mekarim,
You may try this:
1. Open the C:\Program Files\Common Files\Adobe folder and look for a folder starting with Type and meaning Type support; in 10 it is called TypeSpt;
2. Create a namesake folder on your Desktop;
3. Move all the contents to the namesake folder.
Please report back, including the name of the folder.
Ziad
Dubai
ziad.abuoun@yahoo.com
00971 50 2511165
Jun 01, 2008 | Adobe Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
