Had the batterie tested/ good. had the altenator tested/good. put in a new computer with voltage regulator in. charged great first day then nothing next morning. was driveing it and sudenly started working. sat a couple more days and nothing! can anyone tell me what else might be the problem? i assume a wire somwhere but i know theres more under the hood that could be an issue. like for instance there are two small boxes on the inside fender that posative cables go into. what are these and could they pose a charging issue? ive herd this has been an issue with these labarons but i still dont know just what and how to fix this common issue.
SOURCE: 2002 Chrysler Sebring will not start
Mine did the click, click and the timing chain had snapped. If any of you have 2.7 litre engines plan on an engine rebuild or a replacement. Look up the 2.7 engine size along with oil sludge and timing chains. Grab yourself a towel to sop up the tears. This car is 100% garbage and I'm shopping for another non Chrysler product this week.
SOURCE: 1994 crystler labaron alarm system deactivation
I have tried all the solutions for this problem and I still cannot get it to shut off my car alarm system on a 1994 Chrysler Lebasron Convertible GTC? Any other solutions?
SOURCE: car cranks good but won't start
Hello... I applaud all the work you have done so far... A car basically needs ignition, fuel and compression to run. I will leave the compression for last.
But lets do some simple checks.. Even though parts are replaced, check to make sure you have a strong spark, use a spark tester. They are cheap.
Check all powers and grounds running from the ignition system This includes all wires and power cables from the fuse box.
It sounds like something is loss...
I would also have the computer scanned with a scanner to see if there are any codes stored.
Good Luck.... Post back with fix... Thanks
Please see my tip at http://www.fixya.com/cars/r5925550-dead_battery_troubleshooting . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
