Question about Dual XIA1000 Car Audio Amplifier
Remote Wire I have a 94 Cadillac Seville and i have the dual xia1000 in it. The amp is always on it never goes off it is getting continous power. Even if the remote wire is hooked up or not the amp stays on. Can someone help me?
    Novelist:
    Champion:
  • 219 Answers
You have a power supply problem and it is time to go to the repair shop and get it fixed. Sorry about the bad news.
Posted on May 05, 2007
SOURCE:
99 cadillac deville flywheel replacement
1979 Cadillac Coupe 425 engine running; flywheel knocking
? 1:16
https://www.youtube.com/watch?v=UTDBmkKyBCY
Sep 30, 2011 - Uploaded by Edgar H
1979 Cadillac Coupe 425 engine running; flywheel knocking ...Change Transmission Fluid pan removal Cadillac Seville part1 - Duration: .
Exclamation Re: Found a 94 STS for $800, needs flywheel ...
www.cadillacforums.com/.../cadillac-seville-cadillac.../65815-found-94-s...
Feb 16, 2006 - 15 posts - ‎9 authors
Cadillac Seville / Cadillac Eldorado Forum Discussion, Found a 94 STS for $800, needs .... If it is somehow just the flywheel, your repair cost would be the labor involved in dropping ... Automobile(s): 1999 STS - diamond white. Re: flywheel 99 sts
Apr 7, 2013
Re: need to replace flywheel
Dec 3, 2011
Re: Location of transaxle to engine bolts on 1998 ...
Nov 13, 2011
Re: How to lock flywheel without $150 tool?
May 21, 2009
More results from www.cadillacforums.com
Jan 11, 2016 | Cadillac Cars & Trucks
Fuel systeam 94 cadillac
Check fuel Pressure at the motor with a gauge
& also fuel volumn
The pump may work still but the check valve
drains off pressure & it is hard to start
Pump is inside the fuel tank which would have to
come down & out as pump goes in from the top
if that is even the problem
Mar 08, 2013 | 1994 Cadillac Seville
Can i put a fuel pump from a 91 cadillac fleetwood in a 94 seville sts
Check with the auto parts store to see if they both have the same part no's. It's quite possible they are the same.
Dec 25, 2012 | Cars & Trucks
Can i install a fuel pump from a 91 cadillac fleetwood to a 94 seville
If you can check the part numbers stamped on the two different pumps and they are the same then that answers your question.
Dec 25, 2012 | 1994 Cadillac DeVille
Do the 92 and 94 cadillac Seville use the same fuel pump?
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
Sorry but the answer is no.
1991/1992 Part #REPB314517 Fits the following 1990-1992 Cadillac Seville submodels:
1991-1992: Base; 8 Cyl 4.9L; "FI, Naturally Aspirated, VIN B"
1991-1992: STS; 8 Cyl 4.9L; "FI, Naturally Aspirated, VIN B"
1994/1996 Part #E3913M Fits the following 1994-1996 Cadillac Seville submodels:
1994-1996: SLS; 8 Cyl 4.6L; "FI, Naturally Aspirated, VIN Y"
1994-1996: STS; 8 Cyl 4.6L; "FI, Naturally Aspirated, VIN 9
Jun 03, 2012 | Cars & Trucks
I have a 94 cadillac seville it has the 4.6 northstar motor. i need to now how to change the rear main seal. can any body help me with how to do this or have any diagrams? thank you
if i,m not mistaken, that is a rear wheel dr,,, u r going to have to remove the trany.. if u don,t have the tools & a gd friend to help u, suggest find a honest & reliable garage..... that,s the hardest part, charlie
Mar 04, 2010 | 1994 Cadillac Seville
Where is 94 cadillac seville starter at
Assuming its a Northstar engine--under the intake manifold --cant be seen until disassembly
Jan 14, 2010 | 1994 Cadillac Seville
The power windows won't work on the 94 cadiallac seville
Hi sounds like just a faulty window switch,,, or possible a loose wire/connection
Hope this helps
Steve
Mar 18, 2009 | 1994 Cadillac Seville
Dual XIA1000 Car Audio Amplifier Logo
49 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
